Go Back  R/C Tech Forums > North American Regional Forums > Canadian R/C Scene
Overgeared Racing Presents 2015 "Big Chill" November 6-7-8 >
Old 04-24-2015, 08:38 PM
Tiny.24's Avatar
Default Overgeared Racing Presents 2015 "Big Chill" November 6-7-8
We're happy to get the ball rolling Early this year. We have confirmed the Dates for our event and will be working all summer to make "Big Chill" Bigger and Better than it has been in the past.
This will once again be a stand alone event on the Beautiful polished Concrete floor of the Chilliwack Heritage Park. Friday Practice, Saturday Qualifiers and Last chance qualifiers with Single Mains with bump ups on Sunday. More information will be passed along as the decisions are made and sponsors confirmed. Hope everyone can fit this event into their Schedule.
Tiny.24 is offline
Old 05-07-2015, 11:41 PM
valk's Avatar
November this time? Awesome! I can come!
The october weekend was my wife's birthday.
valk is offline
Old 08-15-2015, 01:33 AM
Tiny.24's Avatar
Just a Quick update
GoGo Hobbies has joined with Overgeared Racing to Sponsor this Years 1/12th Scale Stock 13.5 class as well as confirmation that there will be another Keurig Coffee Brewer up for Grabs this year in our Raffle Courtesy of Van Houtte Coffee Services....(no tickets for Ed this year)
Tiny.24 is offline
Old 08-15-2015, 03:52 PM
eevul's Avatar
Did someone say free coffee machine? Should I just pick it up now or will you bother going through the trouble of bringing it to the chill?
eevul is offline
Old 08-29-2015, 11:57 PM
Tiny.24's Avatar
Big Chill returns for the 2015 Season
https://goo.gl/maps/hCJRg
Classes include (Rules to follow)
• Touring Stock 17.5 Powered By Orca America
• options-rc.com Touring Modified
• Apexrc.com World GT 10.5
• GoGo Hobbies 1/12th scale 13.5
• Xpert Servos 1/12th scale Modified
•Gripworksrc.com Formula 1 Rubber 21.5
• G-Force 21.5 Mini
•R/C Pit Stop Big Block Scale Spec 21.5
All races are 6 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Tech inspection….Battery voltage will be checked before the race. Must be at 4.200000000 volts per cell or below. Ride Height will also be checked before the race.
Drivers are required to corner marshal after their race. If they cannot marshal they are required to find their own replacement and inform the Race Director. If the Race Director finds a driver/substitute not corner marshalling, their previous qualifier will be docked 1 complete lap.
There will be a Spec Tire for Touring Stock and Modified…. Sweep QTS. Tires are to be purchased at the track from Overgeared and will be marked. The tires will be between $35-40 Price will be based on US exchange at the time...as close to $35 as we can get.
1 set of tires will be checked in for the weekend and will be marked. Each Class will require its own set of tires.
Practice sets will be available for purchase at the track from Gripworks R/C
Spec Mini
Chassis - Any Tamiya M Chassis car - Assembled as per instruction manual. (IE: No FWD to RWD M-03 conversions)
Unnecessary parts may be left off during assembly (IE: rolls bars on M-05, electronics trays) but no part may be sawed, cut, or milled from chassis.
Drivetrain - Open Diff and Drivetrain, maintaining the kit FDR. 16, 18 and 20 tooth pinions in M-03/M-05/M-06. 17 and 19 tooth pinion only in M-04. 21 tooth pinion not permitted.
Hop Ups - All other Tamiya or aftermarket hop ups are permitted.
ESC – any ESC in BLINKY mode or brushed ESC
Motor – Any 21.5 , Orca 2200kv(or Equivelant) Silver Can Brushed Motor
Wheels/Tires - Tamiya branded mini sized tires and inserts only. Double stuffing not permitted. Any mini sized wheel.
Bodies - Open to any mini sized body with the following restrictions - No touring sedan and/or 12th scale type wedge/Can Am bodies. Bodies must be cut and painted along the factory body lines.
Battery - Any 2S, 7.4V, (without modification to pack or chassis)
Minimum Weight - 1200g
Ride Height - 3mm minimum
Touring Stock 17.5 powered By Orca America
Motor: 17.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: Sweep Handout Tires- 1 Set to be purchased at the track and marked
Weight: Minimum weight 1380g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Motor: Open
ESC: Open ESC
Bodies: Top of wing on touring cars must be equal to or below the roofline in race ready position.
Ride Hight - 5mm minimum
Motor: 10.5 Brushless motor
ESC- ( Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tires: WGT Spec tires
Weight: Minimum weight 930g
Maximum width 200 mm
Bodies: World GT spec bodies only
Ride Height - 4mm minimum
Any on-road 1/10th scale RC vehicle FWD cars will follow the same rules and weight
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: HPI VTA Spec/ HPI D compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1450g
Bodies: anything scale appearing with fenders but not a touring body.
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: Open
Body: F1 style with Moulded Wings. No Lexan Wings.
Width – Maximum 190mm
GoGo Hobbies 1/12 Stock 13.5
Motor: Roar Approved 13.5
ESC: (Blinky)No ESC timing or boost.
Tire – Lilac Spec Tire Must Have Blue Stripe
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
1/12 Open
Motor: Open
ESC: Open
Open Tire
Tiny.24 is offline
Old 09-10-2015, 05:59 PM
Tiny.24's Avatar
Hotels
Closest to Furthest
Best Western Rainbow Country Inn(<5 minutes)
43971 Industrial Way
Chilliwack, BC
V2R 3Z9
604-392-4667
WCICS Discount code (Thank You Josh and WCICS.CA)
01524140 use when calling or booking at bestwestern.ca
Hampton Inn by Hilton Chilliwack(<5 Minutes)
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
Comfort Inn(10 Minutes)
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
Travelodge Chilliwack Hotel(10 minutes)
45466 Yale Rd W
Chilliwack, BC V2R 3Z8
(604) 792-4240
Coast Chilliwack Hotel(15 minutes)
45920 First Avenue
Chilliwack, BC V2P 7K1
(604) 792-5552
Chilliwack Heritige Park also offers the opportunity to camp in their
parking lot with an electrical hookup for $15 per night. You must let
OGR know before race weekend so that we can register you with the Heritage Park.
Tiny.24 is offline
Old 09-29-2015, 10:35 AM
ATDHobbies's Avatar
A few of us were thinking of making the trek down... what time (roughly) are things wrapped up by on Sunday? And Friday... what time can we get in at?
Thanks Anthony
ATDHobbies is offline
Old 09-30-2015, 10:12 AM
Thanks Anthony
If all goes according to schedule, Big Chill Mains should conclude by 3:30 or 4:00pm; it's a little dependent on number of entries, but we know there's going to be (and we welcome) lots of out-o-towners.
Still working out details for Friday, but right now we're aiming to have the track open for practice in the early afternoon. I'll post again as soon as things firm up.
Cheers,
-Doug
V-point is offline
Old 09-30-2015, 05:15 PM
(0000000000)'s Avatar
Count me in! I missed the saskatoon race because of moving, so i am itching to do some rc racing!
Chuck (0000000000)
- TC stock
- Scale Spec
- Mini
- F1
Transponder #'s upon arrival.
(0000000000) is offline
Old 10-12-2015, 11:09 PM
Tiny.24's Avatar
I posted this on the other thread but not this one...
First class $50
Second class $20
Third class $10
Fourth and more $5
Tiny.24 is offline
Old 10-13-2015, 01:59 PM
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I need to get off my duff and make hotel plans. Like it or not, I'm coming!
Brian
Slapmaster6000 is offline
Old 10-13-2015, 05:51 PM
Tiny.24's Avatar
Brian
Great to hear the Slapmaster is making an appearance... thanks for the support
Tiny.24 is offline
Old 10-16-2015, 10:21 AM
Hotel booked. I have a bad, bad plan for you guys. Pull up your socks. This is about to get real.
Old 10-16-2015, 10:22 AM
Ryan, do you want classes and PT's?
Old 10-16-2015, 11:28 AM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
I'm hoping root beer is involved.
R3VoLuTiOn is offline
