Like Tree10Likes
BIG CHILL 2019 Nov,1,2,3
Old 08-28-2019, 12:04 AM
chrisman's Avatar
Default BIG CHILL 2019 Nov,1,2,3
Hi Guys, it's confirmed Nov 1,2,3 is our annual Big Chill at the Chilliwack Heritage Barn.
More details will come. Thanks.
chrisman is offline
Old 09-01-2019, 11:02 PM
chrisman's Avatar
Big Chill returns for the 2019 Season
https://goo.gl/maps/hCJRg
Friday morning, we are forecasting moving in @ 9am and start track build up.
Track will be open Friday from 3pm to 9pm for practice. Racers must Vacate by 9pm.
Early registration will be from 5pm to 8:30pm on Friday evening. The doors will open at 7-9am for practice and registration on Saturday. Registration will close at 8:30am with a drivers meeting at 9:15am. Qualifying will begin at 9:30am sharp. For Sunday, doors will be open at 7am for practice. Last chance qualifying will begin at 9am sharp but time may be pushed to 8am depending on number of racers. We should hopefully be done around 3 to 4pm but this again depends on the number of entries.
Friday November 1st :
Practice 3PM-8:50PM
Early Registration 5PM-8:30PM
Doors Closed 9PM
Saturday November 2nd :
Practice 7AM-9AM
Registration 7AM-8:30AM
Drivers Meeting 9:15AM
Qualifying 9:30AM
Sunday November 3rd :
Practice 7AM
Last Chance Qualifying 9AM, 8AM if needed, will be announced Saturday night.
Mains shortly after LCQ
Trophy Celebration 3PM estimated
CRC black carpet
Classes include
• Touring Stock 21.5
• Touring Modified
• FWD GT Challenge
• 1/12th scale stk 17.5
• Formula 1 Rubber 21.5
• Big Block Scale Spec 21.5
All races are 5 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Tech inspection…Battery voltage will be checked before the race. Must be at 4.200000000 volts per cell or below. Ride Height and weight will also be checked before the race.
Drivers are required to corner marshal after their race. If they cannot marshal, they are required to find their own replacement and inform the Race Director. If the Race Director finds a driver/substitute not corner marshaling, their previous qualifier will be docked 1 complete lap.
There will be a Spec Tire for Touring Stock and Modified…. Tires are R1 wurks carpet 32. Tires will be available for purchase at the track from Overgeared and will be marked per class. The tires will be between $35-40 Price will be based on US exchange at the time...as close to $35 as we can get. 2 set of tires will be checked in for the weekend for TC stock and 2 sets for TC Mod. Each class will require its own set of tires.
Touring Stock presented by Canada Hobbies.
Motor: 21.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: R1 Wurks 32 spec - 2 Set to be purchased at the track and marked
Weight: Minimum weight 1350g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Touring Modified presented by GripworksRC
Motor: Open
ESC: Open ESC
Tires: R1 Wurks 32 spec - 2 Sets (maximum) to be purchased at the track and marked
Bodies: Top of wing on touring cars must be equal to or below the roof line in race ready position.
12th Stock Presented by Team Options-RC
Motor: Roar Approved 17.5
ESC: (Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tire – JFT Blue Stripe Spec Tire on Yellow Wheel --- 1 Set of 4 Provided with Registration by options-rc
Additional sets can be purchased through Overgeared pricing.
OGR at $25 Canadian per set of 4.
Contact the OGR Facebook page to arrange for tires before Big Chill Weekend.
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
Ride Height - 3mm minimum
R/C Big Block Scale Spec (TBA)
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: VTA Spec / HPI D Compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1400g 4WD
Bodies: Scale appearing with fenders but not a touring sedan body.
Wing height 10mm max.
Formula 1 presented by Wings
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: 1050g
Body: F1 style with Moulded Wings. No Lexan Wings. Wings cannot be modified.
Width – Maximum 190mm
Ride Height - 4mm minimum
FWD GT Challenge Presented by Franko Racing
Motor : Handout OGR Orca 17.5
Tires: Gravity R/C USGT Spec Tires
Weight: Minimum weight 1200 FWD
Bodies: Scale appearing with fenders but not a touring sedan body. Hot Hatch design. Wing. No aftermarket add on. Body kit wing supplied only.
TAMIYA
#51497 Volkswagen Golf24
#51339 Volkswagen Golf GTI
#51421 Castrol Honda Civic VTi
#51431 Honda Civic-Type R
#51452 Honda CR-Z
#84144 Renault Clio
#84145 Tom's Levin
#93035
Hyundai Veloster
#93043 Hyundai i-20
#58293 Beams Integra
#58659 Toyota Gazoo
BITTY DESIGN:
#HC-F
MON-TEC:
#019-007 MITO RX
#017-005 WR4
PROTOFORM:
#Europa 1565-25
ABC HOBBY :
#66086 CIVIC TYPE R(EK9)
#66124INTEGRA TYPR-R 96Spec
3Racing:
#LBD-CIVICMK9 CIVIC MK9
HPI
#7340 CELICA TRD
#7043 INTEGRA TYPE R
Please note that we may update the rules as the date gets closer to better match what is currently being run.
Race Format:
Rocket Round Qualifying. Top 8 Cars lock into the A Main… if there are an odd number of cars in the class the lock ins will be determined by there being a 4 car lower main minimum. For example, if there are 11 cars registered there are 7 locked positions. The remaining 4 Cars will race for the final 3 Spots in the Main.
Mains will be Maximum 10 Cars.
Single Mains with Double Bumps. Overgeared has chosen to stay with the unique way of making it exciting for the guys in the lower mains. Top 2 positions from each lower main have the opportunity to Bump Up to the next highest Main.
Race Fees:
$50 1st class
$20 2nd class
$10 3rd class
$5 4th class
Hotels
Closest to Furthest
SureStay by Best Western, formerly Rainbow Country Inn(2minutes)
43971 Industrial Way
Chilliwack, BC
V2R 3Z9
604-392-4667
Comfort Inn(5 Minutes)
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
Travelodge Chilliwack Hotel(5 minutes)
45466 Yale Rd W
Chilliwack, BC V2R 3Z8
(604) 792-4240
Hampton Inn by Hilton Chilliwack(7 Minutes)
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
Coast Chilliwack Hotel(10 minutes)
45920 First Avenue
Chilliwack, BC V2P 7K1
(604) 792-5552
Chilliwack Heritage Park also may offer the opportunity to camp in their parking lot with an electrical hookup. We'll check into the price and post it once we have the info. You must let OGR know before race weekend so that we can register you with the Heritage Park if you are interested in this.
If you have any questions, please let us know as soon as possible.
chrisman is offline
Old 09-03-2019, 12:42 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
some decent deals on expedia.com right now for those hotels posted
Juniorabca likes this.
R3VoLuTiOn is offline
Old 09-04-2019, 12:25 PM
Blue Sky's Avatar
Ron Lui for 1/12 stock and touring stock.
What/who is Franko Racing?
chrisman likes this.
Blue Sky is offline
Old 09-04-2019, 01:09 PM
R3VoLuTiOn's Avatar
You know him quote well
Old 09-04-2019, 07:46 PM
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Planning out my fall/winter fun. Looks like 12 mod got scratched this year? Maybe I can stink at F1 then???
Brian
Slapmaster6000 is offline
Old 09-09-2019, 10:51 AM
Mike Malkinson
TC stock
1 set of tires
malkiy is offline
Old 09-12-2019, 08:42 PM
tpczx6's Avatar
Tim Copp
1/12 stock
and since no Mod 1/12 might bring TC stock
tpczx6 is offline
Old 09-14-2019, 04:27 PM
R3VoLuTiOn's Avatar
Old 09-18-2019, 10:34 PM
tpczx6's Avatar
Airline booked
hotel booked
see you all on that Friday
tpczx6 is offline
Old 10-01-2019, 10:25 AM
jzone's Avatar
Default NOVICE CLASS
No Novice class ? I know a few who would come up to race
jzone is offline
Old 10-01-2019, 11:49 AM
jzone's Avatar
meeeeee....
Touring Stock
F1
USGT
jzone is offline
Old 10-07-2019, 12:06 PM
eevul's Avatar
Registrations are open. Please post in the following format:
Name:
Class 1:
number of tires required:
Class 2:
Class 3:
Number of tires required:
Etc., etc., etc.
Please only post the number of tires per class for those classes that require you to purchase tires at the track. Please read the rules for how many tires you are allowed to purchase. Also include your transponder number if you have never raced at our track.
eevul is offline
Old 10-07-2019, 12:17 PM
(0000000000)'s Avatar
Chuck
- TC Stock - 1 set
- TC Mod - 1 set
- Scale Spec
(0000000000) is offline
Old 10-08-2019, 03:27 PM
Tiny.24's Avatar
Tiny
Touring Stock
4 tires... 🤪
Tiny.24 is offline
