Go Back  R/C Tech Forums > North American Regional Forums > Canadian R/C Scene
Overgeared Racing Presents 2018 "Big Chill" November 2-4 >
Like Tree37Likes
Old 09-10-2018, 06:25 PM
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
Default Overgeared Racing Presents 2018 "Big Chill" November 2-4
Big Chill returns for the 2018 Season
https://goo.gl/maps/hCJRg
Track will be open Friday from 3pm to 9pm for practice. Racers must Vacate by 9pm.
Early registration will be from 7pm to 8:30pm on Friday evening. The doors will open at 7-9am for practice and registration on Saturday. Registration will close at 8:30am with a drivers meeting at 9:15am. Qualifying will begin at 9:30am sharp. For Sunday, doors will be open at 7am for practice. Last chance qualifying will begin at 9am sharp but time may be pushed to 8am depending on number of racers. We should hopefully be done around 3 to 4pm but this again depends on the number of entries.
Friday November 2nd:
Practice 3PM-8:50PM
Early Registration 7PM-8:30PM
Doors Closed 9PM
Saturday November 3rd:
Practice 7AM-9AM
Registration 7AM-8:30AM
Drivers Meeting 9:15AM
Qualifying 9:30AM
Sunday November 4th:
Practice 7AM
Last Chance Qualifying 9AM, 8AM if needed, will be announced Saturday night.
Mains shortly after LCQ
Trophy Celebration 3PM estimated
CRC black carpet
Classes include
• Touring Stock 21.5
• Touring Modified
• 1/12th scale 17.5
• 1/12th scale Modified
• Formula 1 Rubber 21.5
• Big Block Scale Spec 21.5
• Tamiya Euro Truck
All races are 5 minutes in duration with the exception of the 1/12th Scale cars at 8 minutes.
Tech inspection…Battery voltage will be checked before the race. Must be at 4.200000000 volts per cell or below. Ride Height and weight will also be checked before the race.
Drivers are required to corner marshal after their race. If they cannot marshal, they are required to find their own replacement and inform the Race Director. If the Race Director finds a driver/substitute not corner marshaling, their previous qualifier will be docked 1 complete lap.
There will be a Spec Tire for Touring Stock and Modified…. Tires are To be announced. Tires will be available for purchase at the track from Overgeared and will be marked per class. The tires will be between $35-40 Price will be based on US exchange at the time...as close to $35 as we can get. 1 set of tires will be checked in for the weekend for TC stock and 2 sets for TC Mod. Each class will require its own set of tires.
Touring Stock presented by R1 Wurks
Motor: 21.5 Brushless motor ROAR Approved
ESC: (BLINKY) No ESC timing or boost.
Battery: 2S Li-po hard case batteries only
Tires: TBA 32 spec - 1 Set to be purchased at the track and marked
Weight: Minimum weight 1350g
Bodies: Top of wing on touring cars must be equal to or below the roof-line in race ready position.
Ride Height - 5mm minimum
Touring Modified Presented by About RC Racing - ORCA
Motor: Open
ESC: Open ESC
Tires: TBA 32 spec - 2 Sets (maximum) to be purchased at the track and marked
Bodies: Top of wing on touring cars must be equal to or below the roof line in race ready position.
12th Stock Presented by options-rc.com
Motor: Roar Approved 17.5
ESC: (Blinky)No ESC timing or boost.
Battery: 1S Li-po hard case batteries only
Tire – JFT Blue Stripe Spec Tire on Yellow Wheel --- 1 Set of 4 Provided with Registration by options-rc
Additional sets can be purchased through Overgeared or Seattle RC racers at their club pricing. OGR at $25 Canadian per set of 4.
Contact the OGR Facebook page to arrange for tires before Big Chill Weekend.
Weight: Minimum weight 730g
Bodies: 1/12 cars must run Can-Am/Lola style bodies.
Ride Height - 3mm minimum
12th Modified Presented by SMK Smokery and Bar
Motor: Open
ESC: Open
Open Tire
R/C Big Block Scale Spec Presented by Gripworks RC
Motor: Any 21.5 Open Gearing
ESC: (Blinky) No ESC timing or boost.
Tires: VTA Spec / HPI D Compound or Gravity R/C USGT Spec Tires
Weight: Minimum weight 1400g 4WD / 1200g for FWD (front wheel drive)
Bodies: Scale appearing with fenders but not a touring sedan body. Wing height 10mm max.
Formula 1 Presented by Hi Performance Distributors
Motor: 21.5 or Silver Can
ESC: (Blinky) No ESC Timing or Boost
Tires: Rubber Only
Minimum weight: 1050g
Body: F1 style with Moulded Wings. No Lexan Wings. Wings cannot be modified.
Width – Maximum 190mm
Ride Height - 4mm minimum
Euro Semi-Truck GT Presented by Rebel Concepts
This is a pure box stock class open to any skill level hobbyist.
1. Legal kits: Item 58632 RC Team Hahn Racing MAN TGS (TT-01 type E chassis) & Item 58642 RC Team Reinert Racing MAN TGS (TT-01 type E chassis)
2. The kit must be built exactly per the instruction manual.
3.(The ONLY Hop-Op Option permitted is Ball Bearings.)
4. Must use stock pinion (19T) and spur gear (61T).
5. The kit Tamiya TBLE-02S ESC and kit supplied motor (item 54358 RS-540 Torque Tuned Motor) must be used. Battery connector may be changed to DEANS. Motor Bullet connectors may not be removed.
6. All body parts must be used.
7. Body may be painted in any scheme.
8. Must use kit tires and wheels. Kit tires may be glued onto wheel.
9. Any grease or lube may be used to lubricate gears or moving parts.
10. Batteries: Any round hardcase LiPo battery max capacity 5000mah may be used for this class.
  1. No Additional Weight or Ballast can be added to the Vehicle
  2. If it’s not in the Spirit of the class it won’t be allowed.
Please note that we may update the rules as the date gets closer to better match what is currently being run.
Race Format:
Rocket Round Qualifying. Top 8 Cars lock into the A Main… if there are an odd number of cars in the class the lock ins will be determined by there being a 4 car lower main minimum. For example, if there are 11 cars registered there are 7 locked positions. The remaining 4 Cars will race for the final 3 Spots in the Main.
Mains will be Maximum 10 Cars.
Single Mains with Double Bumps. Overgeared has chosen to stay with the unique way of making it exciting for the guys in the lower mains. Top 2 positions from each lower main have the opportunity to Bump Up to the next highest Main.
Race Fees:
$50 1st class
$20 2nd class
$10 3rd class
$5 4th class
Hotels
Closest to Furthest
SureStay by Best Western, formerly Rainbow Country Inn(2minutes)
43971 Industrial Way
Chilliwack, BC
V2R 3Z9
604-392-4667
WCICS Discount code (Thank You Josh and WCICS.CA)
01524140 use when calling or booking at bestwestern.ca
Comfort Inn(5 Minutes)
45405 Luckakuck Way
Chilliwack, BC
V2R 3C7
(604) 858-0636
Travelodge Chilliwack Hotel(5 minutes)
45466 Yale Rd W
Chilliwack, BC V2R 3Z8
(604) 792-4240
Hampton Inn by Hilton Chilliwack(7 Minutes)
8050 Lickman Rd
Chilliwack, BC
V2R 3Z9
(604) 392-4667
Coast Chilliwack Hotel(10 minutes)
45920 First Avenue
Chilliwack, BC V2P 7K1
(604) 792-5552
Chilliwack Heritage Park also may offer the opportunity to camp in their parking lot with an electrical hookup. We'll check into the price and post it once we have the info. You must let OGR know before race weekend so that we can register you with the Heritage Park if you are interested in this.
If you have any questions, please let us know as soon as possible.
R3VoLuTiOn is offline
Old 09-10-2018, 10:12 PM
tpczx6's Avatar
Sign Me up
!/12 stock
1/12 mod
maybe 1/10 stock also
R3VoLuTiOn likes this.
tpczx6 is offline
Old 09-11-2018, 10:49 PM
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
John,
Thanks for info. This race is always a lot of fun. You know we'll grab a crew from the "south" for a visit "north".
Brian
Slapmaster6000 is offline
Old 09-18-2018, 11:53 AM
patorz31's Avatar
Sign me up
TC Stock.
12th Stock
extra tires for 12th please.
patorz31 is offline
Old 09-21-2018, 05:16 PM
Giuseppe's Avatar
Default Pre Reg
I'm in:
TC Mod
12th Mod
Scale Spec (Maybe)
Giuseppe is offline
Old 10-01-2018, 11:07 PM
Default Pre-reg
Sign me up for the following please.
TC Stock
F1
12th Stock - extra set of tires for 12th please
Jon
Juniorabca is offline
Old 10-03-2018, 08:03 PM
Tiny.24's Avatar
Tiny
Options-rc.com 12th stock
R1 Wurks Touring Stock.
Tiny.24 is offline
Old 10-04-2018, 09:59 AM
Company Representative
Trader Rating: 15 (100%+)
Korgae Scales
TC Mod
12 Mod
Korgae is offline
Old 10-04-2018, 10:44 AM
(0000000000)'s Avatar
TC Stock
TC Modified
(0000000000) is offline
Old 10-08-2018, 06:07 PM
eevul's Avatar
Alright guys this race is coming up soon and I'm starting to do the registrations. Please make sure to include your name and transponders as this will help me greatly.
Format:
Name:
Class:
Transponder #:
Class:
Transponder #:
Class:
Transponder #:
You get the point. If you have attended the race previously and have the same transponders, then you could just put " on file" in the transponder field.
Thanks!
chrisman likes this.
eevul is offline
Old 10-12-2018, 02:25 PM
valk's Avatar
Nick Keown
Open TC
5131201
Open 1/12th
3551798
im pretty sure ive raced at ogr with all my transponders but ill update explicit information once i build the cars lol.
valk is offline
Old 10-12-2018, 04:41 PM
Daryl Jones
1/12 stock
TC stock
1 extra set of 1/12 tires
Transponders on file
dajracer is offline
Old 10-15-2018, 06:38 AM
eevul's Avatar
Thanks guys! Keep em coming!
eevul is offline
Old 10-15-2018, 08:00 PM
tpczx6's Avatar
Tim Copp
1/12 stock
2477542
1/12 Mod
3519622
tpczx6 is offline
Old 10-15-2018, 10:50 PM
Brian Bodine
12 stk 8112916
12 mod 7067036
I'd like to park the RV on the close side once again. AC power not needed. I think Ryan was going to give the parks a heads up.
