Questions about rc flying in brunei
#16
Si Thu Zaw,
Just seen this morning in the for sale section, there is a Futaba 6ex with recevr for sale at $250.... check it out..... seller gwan
This radio is a computer radio with mixing and heli functions, so it should be able to open up your options... also it has expo and dual rates which is going to be very handy to tune the craft to your hands.....
With regards to the radio's at Warisan, i am not sure what the prices are like, you can check them out yourself....
#17
Is there a TX and RX set under 100$?
Building myself will cost about 170$-250$ right?
So does buying a 3ch or 4ch plane cost more than building?
If not,I'll buy it,fly it and pull the parts out of it and put it on another plane so I won't need to spend a lot on TX and RX.
#18
If you can find those RTF (Ready to Fly) models with radios & receiver included, then you may be able to save on the costs.. you can always use back the radio for crafts which you build yourself. I recall last time, we were able to get this electric powered 4 ch glider for just over $100 with a basic 4ch radio. (Triple Star in Kiulap - bicycle/ baby store)
Basically buying a radio is the initial investment to get you in the hobby. As you build, buy and progress on other aircrafts be it fixed wing or rotaries, you can carryover the same equipment.
So what it boils to is how much you are willing to spend.... I always say, buy the most expensive radio you can afford.... that way you will not have to spend on radios as your skills improve and your needs/ demands over features increase.
#19
I know but I just don't want to spend hundreds of dollars on my first plane,first build.
#20
My guess will then be that you should look for those RTF's first, at least with a minimum of 4ch to experience real flying... Avoid the 2 or 3ch where you will grow tired quickly since you already have experience on the sim.
Going for self-build crafts will require some initial cash outlay to get you started.... it is then when you recycle the parts (e.g. motor/ electronics/ radio equipment) that it becomes cheaper to build since now you only have the cost of the airframe.
Try dropping by Triple Star (in Kiulap upstairs) or Little M (in Batu Bersurat). I have not been there lately myself, but they had some pretty decent low cost RTF's. The powered glider i told you about cost me like $120 and it was around 2 years back.....
#21
Can I buy foam at hardware shops?
#22
divinity like zagi
i made this by 2 sheet of depron foam 6mm. dont cost to much.
1st divinity
.[IMG][/IMG]
2nd divinity with carbon spar
1st divinity
.[IMG][/IMG]
#23
How much would they cost including the radio systems?
#24
RC heli lessons
Hi Guys,
Can anyone one here give RC petrol helicopter flying lessons or do you know anyone who can? I have my own heli but not confident, willing to pay the going rate.
#25
#26
Try to look for either Phenoix or Realflight or Reflex.... believe me if you can fly on the sim you will be able to fly the real thing.....
#27
jeng mcmna kmu mbuat a,mcm kn join jua main,sal mbli heli ku,belt cp p men dpn umah ja..a2 pakai form yg ara bismi ka?n design buleh buat sesuka hati o mcmna?iski jua kn main glider a...
#28
sanang ganya membuat ni. ada plan nya ni. arah rcgroups.com pun banyak jenis kapal made by depron foam ah. just look under plane scratchbuild. foam nya bleh d dapati d mana2 kadai buku. ku recommend kadai stationary dpn aneka rasa d qlap. sal apa, kadai mcm bismi or tajul kh, nipis wh mcm low quality.
#29
#30
