Go Back   R/C Tech Forums > International Forums > Brunei R/C Racers
Thread Tools Search this Thread Rate Thread
Old 11-28-2009, 10:10 PM   #61
Vs
Hai to all r/c pro..Kn btnya.Ku ada remote MX-3FG FHSS 2.4 GHz yg baru tp aku nda pndai setting.Asal sja ON,nda mau reverse.N kdang2 pndai bjln sndri.So sapa2 ada tau sal masalah ani.Plz..Share lh k..Tq.
Vs is offline   Reply With Quote
Old 11-28-2009, 10:15 PM   #62
Akudou's Avatar
Check your throttle trim. Kalau ia d takan sekali berjalan sendiri ke depan, angkat your rc dulu then set ur throttle trim more to reverse sampai ia berhenti. Then di takan throttle liatkan mau jalan kah inda then cuba jua reverse nya. Make sure arah menu your throttle EPA cukup tinggi or else you have to reset the receiver unit
Akudou is offline   Reply With Quote
Old 11-28-2009, 10:34 PM   #63
Vs
Default Question?
Hai to all r/c fanz.Kn btnya,ku ada Sanwa MX-3FG FHSS 2.4GHz yg bru.Tp aku nda pndai setting,sal ja ku ON,nda mau reverse n kdang2 pndai bjln sndri.So f sapa2 yg tau cna solve problem ni.Plz share..Tq..
Old 11-28-2009, 10:50 PM   #64
Vs
Bro,cna kn reset receiver tu balik?
Old 11-29-2009, 03:36 AM   #65
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
bro mx3 yg bru ne sma mcm m11s,u just try 2 reset dri tmpt rec,ada lmpu biru ntk crystal,ko tkn ja dlm 3sec..but a2 ntk m11s plg 2,but cba2 ja
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 11-29-2009, 04:23 AM   #66
Vs
Bro..Mau plang udh kdpan n reverse tp masalahnya lg,stiap kali ku braking n reverse,my ESC blinking warna hijau n nda mau foward lg.Smpai blinking hijau tu ilang,bru mau foward lg..
Old 11-29-2009, 04:33 AM   #67
g-wan's Avatar
k,u chck ia pnya EPA ntk th,besa mx3 o m11 pnya th 140,try to reduce
Old 11-30-2009, 02:21 AM   #68
VR6T's Avatar
Originally Posted by Mel279 View Post
Rcboat?LMK if anyone one here interested especially on EP or FE rcboat. Love this hobby because of less maintenance and spare part , sadly not many LHS support this hobby
and we only have ...5 shop that selling RC stuff (suitable for adult) in Brunei
VR6T is offline   Reply With Quote
Old 12-15-2009, 10:29 AM   #69
Pentagonist's Avatar
Dear RC racers.
Can you pros, kudos and gurus tell me what's the use and purpose of each item that appear on my brushless program card. I got this cute lil program card and here is the item that I really want to know Please share your knowledge to kill my noobness. Looking at the item listed below, some of you might already know what brand is my Brushless :P So I dont think I need to intro it to you guys. Now, SHOOT!
Item 2. Drag Brake Force?
Item 4. DRRS Start mode (Punch)?
Item 7. Initial Brake Force?
Item 8. Neutral Range?
Item 9. Timing?
No Name, No Fame, But I Got Game.
Pentagonist is offline   Reply With Quote
Old 12-15-2009, 09:42 PM   #70
raw -b's Avatar
Default Need Help A.S.A.P
esc ku, kyosho perfex ka-15, nda mau reverse and brake, udah ku ikut manual instructionnya masih jua nda mau, tolong ku ah, kepada pakar pakar r/c okay.....
''Drift Is An Art Of Handling The Curve''
raw -b is offline   Reply With Quote
Old 12-15-2009, 09:50 PM   #71
zamtibook's Avatar
Default Cleaning your cars?
Bros, I know if main yang on road cars sanang saja brushing off the dirts pun sdh cukup. how bout buggies/offroaders? is it ok if ku take off smua electronics, then ku siram saja kai air. hehhehe.. btw. mini air compressor yang ada bjual mcm d huaho yayasan tu ok ka/. sadang kuatnya if ku kn pakai air-off cars after every play?
Zam @8225072
Crawling!
zamtibook is offline   Reply With Quote
Old 12-15-2009, 10:17 PM   #72
Originally Posted by zamtibook View Post
how bout buggies/offroaders? is it ok if ku take off smua electronics, then ku siram saja kai air. hehhehe.. ?
for 1/8, no problem
Never did that to 1/10. But if it's running a belt drive system, I think better not
cheapskate.brok is offline   Reply With Quote
Old 12-15-2009, 10:45 PM   #73
zamtibook's Avatar
Default kv vs mah?
im running zx5. stock motor plang masih. but ku rasa nda bata la run timenya on my 3600mah lipo. iatah rasanya kan membali lipo lagi and motor.
ok how bout this. in theory
if lets say, 2600kv + 3000mah 2cell can play like 10 mins,
artinya 1800kv + 3000mah 2cell can play alot longer tah tu?
but of course 2600kv much speed than 1800kv?
and 2600kv more torque than 1800kv?
ngam kah? minta confirmkan manatau salah kefahaman ku googling atu td.
Zam @8225072
Crawling!
Old 12-15-2009, 11:24 PM   #74
Mel279's Avatar
bro
bleh tu p ko mesti karingkan jua, lapas atu ko pasang undertray khas utk zx5, ndatau ada ka bjual d GHL atu. Gunanya supaya kurang dirt msuk rah zx5 mu atu.
My Fleets:
EPV 135 twin cat 53"
Proboat Stiletto 29 tunnel
Delta Force copy 41" mono
HPR115 Triple X
Mel279 is offline   Reply With Quote
Old 12-15-2009, 11:42 PM   #75
zamtibook's Avatar
Default LiPo
EHE, banyak eh Q's ku ah....
Lipo batt: it is adviced not to run it when the volt is under a specific minimum... (to jaga the life laa. kan?)
Then mcmmana kita kan tau the volt is sampai rah minimum sudah semasa main?
Zam @8225072
Crawling!
