Newbies Queries
#47
Digital caliper.
Aku mencari digital caliper. D mana Ada bjual?
#48
#49
There's a hardware shop after Jolibee in Delima. I think there are two but there is only one of them that sells "STANLEY" brand tools. They still have digital calipers that can measure up to .00mm which imo is good enuf for most applications. should cost around B$38
#50
FUTABA ESC
Esc futaba can until how many turn
#51
#52
Isn't that your brand? Cos it bears your name on it....
#53
#54
Digital caliper found
I've found the digital caliper. The shop is "chemiland" sama simpang with jolibee serusop(iakah). It's not from Stanley though but only from sellery. Made of some sort of plastic. I was looking for metal digital caliper. But tired sdh mencari sana sini so balisaja Tia. Costs $34. Thnx for the tips
#55
Kan belajar...
mcm mana kan mensetup adjustable absorber and spring for Kyosho TF5 & Kyosho ZX5??
Minyak absorber jenis apa?tabal nya?
Spring apa bagus?Hard or soft?or medium?
Anyone experience in touring & buggy please share info ah...
#57
rubber tyre
front
1.5 camber
.5 toe
ride height 5mm
mid soft spring (black)
shock oil 350 cst from tornado(35wt)
shock hole #2
shock position mid
lower shock pos outside std position
stabilizer 1.1
rear
1.5 camber
ride height 5.5mm
mid hard spring (gold)
shock hole #1
shock position #4 out
lower shock position std
stabilizer 1.2
pinion gear 29T 64p
spur gear 98T 64p
form tyre
front
2 camber
0 toe
ride height 4.5mm
medium spring
shock oil 400 cst from tornado(40wt)
shock hole #2
shock position mid
stabilizer 1.2
rear
2 camber
ride height 5mm
medium spring
shock hole #1
stabilizer 1.2
pinion gear 32T 64p
spur gear 100T 64p
but this setup best for me to drive since i still drive tf5 n fw05rr,so u jst cba cri setup yg sesuai for ur skill n test it,adjust ckit2 setup 2,insallah ur setup will be perfect
#58
Pinion hex screw
Bros. Cemana ah? Hex screw rah pinion gear ku rusak sdh hex nyaa. Loose. Masih lg rag motor ku tu. Cemana kn membuka tu ah? Lau ku plahan2 drill saja hex atu dpt ka tu? OfcoZ nda dpt pkai lg laa pinion ah. Cmna?
#60
If you fiddle too much on the motor shaft while trying to remove a stubborn pinion gear, you can throw off the microseals in the motor bearings. The Macguyver way would be to drill out the hex grub screw to accommodate a larger screw and this will work, it just takes time. another way to do this without putting undue on yr motor shaft bearings is to get a pinion puller. Go to any good hardware store and find a mini gear puller (looks like a claw type with screws), intall this on yr motor and it'll remove yr pinion/gear in seconds. its good to have this specialty type of tools to get out of these situations. hope this helps
