Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Sanwa MT-S now in STOCK @ BanzaiHobby >
Old 12-03-2015, 06:14 AM
Company Representative
Arrow Sanwa MT-S now in STOCK @ BanzaiHobby
Sanwa MT-S now available at Banzai Hobby!
Sanwa 101A31902A MT-S with RX481 Receiver
Sanwa 101A31901A MT-S with RX-482 Receiver SSL
UNUSUAL ABILITY IN THE CLASS
LONG-AWAITED DEBUT
MT-S CAME ON!!!
<FEATURES>
1 SETUP WIZARD FOR EASY SETTING
CAR TYPE(8 MODEL TYPES) CAN BE SET EASILY.
2 SSL (SANWA SYNCHRONIZED LINK)-COMPATIBLE
The compatible equipment can be set by transmitter
through CODE AUX functions.
?Compatible equipment: SUPER VORTEX SERIES,
SV-PLUS SERIES, SGS-01C (Gain Adjustment)
3 LIGHT BODY (366g)
EASY OPERATION FOR CHILDREN
MIDDLE CLASS (ENTRY LEVEL)
WHITE LED BACK LIGHT?LARGE FULL-DOT LCD MONITOR(128x64dot)
ST TH TENSION ADJUSTMENT?ADJUSTABLE TRIGGER?BUILT-IN ANTENNA
TELEMETRY FUNCTION?DUAL RATE?SERVO SPEED?SERVO REVERSE
TRIM/SUB TRIM?CURVE(EXPONENTIAL / ADJUSTABLE RATE CONTROL)
FAIL SAFE(RADIO WAVES / BATTERY)?EPA?OFFSET?BIND?BASE
FUNCTION?TH TYPE(70:30/50:50)?ANTI-LOCK BRAKE?MODEL NAME(10 LETTERS)
MODEL MEMORY(20 MODELS)?MODEL(SELECT/CLEAR/COPY)
TIMER(LAP / INTERVAL / DOWN)?LOGGER?ALERT SETTING?TELEMETRY SETTING
KEY ASSIGN(SW / TRIM)?BUZZER(SCALE / VOLUME CHANGEABLE)
TRANSMITTER BATTERY ALARM?LCD CONTRAST?VOLUME ADJUSTMENT
SETUP WIZARD?RF MODE SETTING(FH4/FH3)?RESPONSE MODE (NOR/SHR/SSR)
DIRECT MODEL SELECT?AUX1(SELECT THE OPERATION TYPE OF 3CH)
AUX2(SELECT THE OPERATION TYPE OF 4CH)
AUX TYPE SETTING
CODE AUX (COMPATIBLE WITH SUPER VORTEX ZERO & TYPE-D MENU)
STEP AUX (STEP 1 to 100)
POINT AUX (2 to 6 POINT)
4WS MIXING (FRONT/REAR/NORMAL/REVERSE
MOA MIXING(FRONT-WHEEL-DRIVE/4WD/REAR-WHEEL-DRIVE)
*DRIVE RATE IS VARIABLE.
AUX MIXING (ST MIXING, TH MIXING)
4 CELL DRY BATTERY
COMPATIBLE RECEIVER; RX-380, RX-381, RX-451, RX-451R, RX-461, RX-462, RX-471,
RX-472, RX-481, RX-482
[SSL(SANWA SYNCHRONIZES LINK) SYSTEM]
SANWA NEW SSL SYSTEM
When used with compatible RX-472, RX-482, Super Vortex Series, SV-Plus Series, the setting of ESC etc. by Transmitter is available through SSL functions while driving.
Since the setting can be done without the stop of car, the detailed adjustment in accordance with Race conditions
is available without interruption of Intervals and the change of machine conditions.
[RESPONSE OF TELEMETRY SYSTEM]
It is often said that telemetry system reduce response speed. However, SANWA Original Data Processing and Algorithm Design makes Telemetry possible without response speed reduction.
Our Excellent Telemetry System has no response speed reduction.
With our telemetry system, the precious race data will help the next race setting and driving.
[RESPONSE MODE]
Please do not use Analog Servo for SHR mode or SSR mode.
If analog servo is used for SHR mode or SSR mode, the servo will be broken and will not work.
Digital servo (SRG series, Digital ERG series, SDX series) can be used both for NOR mode and SHR mode.
SSR mode can be used only by SRG series servo.
In SHR or SSR mode, BL-RACER, BL-FORCE, BL-SPORT, F2000, F2200, F3000, F3300, SBL-01, SBL-02 and SBL-03CR do not work.
Please use NOR mode for the above ESC.
SV-08, HV-10, HV-12, F2500 can work by NOR/SHR MODE.
BanzaiHobby is offline
