Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
ヾ= ̄∇ ̄)ノ Pre-Order: Wrap-Up Next Nervis Conversion Kit >
Old 07-16-2015, 10:48 PM
Company Representative
Arrow ヾ= ̄∇ ̄)ノ Pre-Order: Wrap-Up Next Nervis Conversion Kit
Wrap-Up Next Nervis Conversion Kit now available for PRE-ORDER!
Place your PRE-ORDER Now and we will make sure you will receive Wrap-Up Next Nervis Conversion! as soon as it is released. We highly recommend pre-order due to limited quantity.
ETA: Mid July 2015
Further more! If you pre-order Nervis now and we will include one of RC Drift Video DVD (worth JPY2,000 - JPY3000)!!
So don't miss this opportunity!!
Wrap-Up Next RWD chassis lay out with NEW VX-DOCK >> NERVIS Conversion Kit
Servo is positioned center of Front Bulk and linked direct to slide rail.
Chassis Layout is Rear Motor perfect for RWD Drifting with reversible Motor Mount. You can choose motor position left or right.
Can be used with many Yokomo Drift Package optional parts.
Features:
* VX-DOCK Slide Steering Unit
* Reversible Aluminium Motor Mount (You can choose motor position left or right)
* 2.5mm CFRP Black Carbon Main Chassis
* 2mm CFRP Black Carbon Upper Deck
* Can be used with Yokomo or Tamiya Suspension Block
* Straight, Short Lipo, Left / Right, many battery position
* RWD Short Input Chassis (Drift Package)
* Aluminium Front Upper Mount
* Newly designed Aluminium Rear Mission Mount (Drift Package / FR-D)
This is conversion kit for Yokomo Drift Package
Nervis Kit consists of:
2.5mm Pure Carbon Main Chassis
2mm Pure Carbon Upper Deck F
2mm Pure carbon Upper Deck R
VX-Dock Slide Steering System
Reversioble Aluminium Motor Mount
RWD Short Input Shaft
Aluminium Front Upper Deck Mount
Screws etc.
(Input shaft cannot be used with Gear Diff)
Require:
Long adjustable Servo Horn
Drift Package Suspension system (Suspension arm, Suspension Mount, Suspension Shaft, Knuckle, Turnbuckle, Ball end etc).
Drift Package Rear Shock Tower
F&R Oil Shock
Drift Package Mission (Rear)
Drift Package Spur Gear Holder
Yokomo D108 Imadoki COnversion Battery Holder or Wrap-Up Battery Holder & Mount
4 Colors to choose from!
Wrap-Up Next 0160-FD NERVIS Conversion Kit (Silver)
Wrap-Up Next 0161-FD NERVIS Conversion Kit (Black)
Wrap-Up Next PRE-Order 0162-FD NERVIS Conversion Kit (Blue)
Wrap-Up Next 0163-FD NERVIS Conversion Kit (RED)
BanzaiHobby is offline
