Yokomo Drift Package 2WD Conversion
Yokomo D-162P Drift Package RWD Conversion PRO201
RWD conversion Kit for Drift Package is now available from YOKOMO!!!
Newly designed steering wiper will give you heaps of Counter Steering Angle which is important for RWD.
Furthermore, wide range of Ackerman ratio will make sure, you can RWD drift on any surface!
This conversion PRO201 include front Aluminium shock tower, Aluminium Upper Arm, Aluminium Upper Arm Support.
Upper arm pivot position can be selected so pressure to front tires during drifting can be also controlled. Just like Real 2WD Drift!!!
Main Feature:
Aluminium Front Shock Tower
Aluminium Upper Arm
Aluminum Lower Arm
Aluminum Narrow Scrub Knuckle
Aluminum Super Long Steering Bell crank
Also available with;
Yokomo D-162R 2WD DRIFT Conversion RS 201 for DRIFT PACKAGE
Main Feature:
Aluminium Upper Arm
Aluminum Lower Arm
