Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
NEW Kawada F500WS Formula One Kit >
Old 04-15-2015, 04:28 PM
Company Representative
Thumbs up NEW Kawada F500WS Formula One Kit
The new Kawada F500WS F1 Kit is now at Banzai Hobby
One of the best and perfect 1/10 scale F1 RC Car released from from Kawada!
If you are looking for precision, perfect F1 RC car, this is your choice!
Made in Japan
Feature:
Carbon & Resin Hybrid Suspension Arm (Precision & Rigidity)
SDS Front End include small friction damper (ensure grip)
Slim & Low chassis design (perfect control ability)
High Precision, Large Capacity HG Tube Damper (Create stable roll)
You can choose ackerman position freely. (Find perfect handling position)
You can choose battery position freely. (Find perfect weight balance position)
* Carbon Chassis,
* Upper Brace
* Damper Brace
* Lower Brace
* Lower Suspension Plate
* Upper Arm
* Damper Bridge
* Battery Holder
* Motor Mount Support
* Servo Mount (T=2.5mm)
* Duraluminium Motor Mount (L&R)
* Aluminium right hub
* High Precision clamp type left hub
* 1/4" Carbon Rear Shaft
* Carbon + Resin Hybrid Suspension Arm
* Duraluminium ball connect type front bulk
* Delrin Pivot ball
* Diaphragm type Ptiching Damper
* High Precision Aluminium HG Tube Damper
* Clamp type one piece side link
* One piece ball sheet
* Servo Saver
* Full Ball Bearing
Get in Quick as Stock is Limited
Also check us out on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
BanzaiHobby is offline
