NEW Active Hobby Products
New From Active Hobby the new Magnet Body Mount Marker and Off-Road Vehicle Wheel Lock Nut now at Banzai Hobby!
Product Features
6mm and post to be used in 1/10 scale car, I corresponds to the post of 5mm drift package system.
※ drift package, etc. use the spacer black accessories.
Was attached to the body posts, and cover the body. Was placed on a magnet attached After you determine the position, please marked with felt pens.
Product Features
Reproduced the hub of the actual vehicle 4x4, is a wheel nut realistic scale.
Because it is embedded a special 4mm nylon nut inside, you can use any type of vehicle in the wheel nut like normal.
(W / 4mm wrench into 9mm / 4 co-height diameter 11mmx)
CC01 CR01 GF01 Tamiya, etc., It is the design which is the best match to crawler-based and cross-country chassis.
Please Check us out on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
Product Features
Product Features
Banzai Hobby Team
New Active Hobby Products now at Banzai Hobby!!!
A AWESOME Way to dress up some much need bling to your Yokomo Drift Package or other drift kits with the new Products from Active hobby
Pillow Ball Mount Shock End for Drift Package
Pillow Ball Turnbuckle Tie Rod S (34 - 48mm 2pcs)
Pillow Ball Turnbuckle Tie Rod L (34-68mm 2pcs)
High Angle Rod End C Foot for Drift Package 2pcs
Get in Quick as these are Limited runs and will Sell FAST!!!!!
Please join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Banzai Hobby Team
The New Line up for Active Hobby is now at Banzai Hobby!!!
High Angle Steering Rod Set
In shape to avoid the interference of the wheel, is the steering rod of stainless steel balls inserted already capable of handling even narrow scrub
TRF Length Adjustable Pillow Ball Cap
· It is a shock cap set that can adjust the vehicle height without changing the pretension. (Adjustment range genuine + 1mm ~ + 3.5mm)
. In stainless pillow ball inserted already, I will achieve the mount with no backlash.
Banzai Hobby Team
Banzai Hobby Team
Looking at something new to Dress your Drifter/Racer up with then look no more with the new Active Hobby Accessories
Wide Flange 4mm Wheel Lock Nuts
5 Hole Wheel Nuts Silver
5 Hole Wheel Nuts Black
5 Hole Wheel Nut Socket (7mm)
Wheel nut socket designed for the 5 Hole Wheel Nuts
TRF Damper Pillow Ball Mount Shock End (2pcs)
Banzai Hobby Team
Banzai Hobby Team
Active Hobby Aluminum Upper A-Arm Type C (2pcs) now at Banzai Hobby!!!
Comes in 5 Colors to match your Drifter
Blue
Dark Blue
Black
Red
Silver
Adjustable to 37.5 ~ 52mm Upper arm length
Largely improves the strength at the weak point of the single A arm
also im improves an removing slop an play in the caster
Please join us at Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Blue
Dark Blue
Black
Red
Silver
Banzai Hobby Team
Wanting to Dress up your WR02 Wild Willy 2 well look no more the new items from Active Hobby for your Wild Willy are Here!!!
WR02 Aluminum 7 Slot Grille Wild Willy 2
Also for the Drifters out there!!!
Yokomo Drift Package & Tamiya TRF Damper Tapered Piston 3/4-Hole
Please Join us at Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Banzai Hobby Team
Sorry JatoTheRipper with the latest system update's we have had some errors
i hope this helps
WR02 & GF01 Aluminum Chassis Skid Bumper and Aluminum 7 Slot Grille Wild Willy 2
Banzai Hobby Team
i hope this helps
Banzai Hobby Team
The Pillow Ball Shock Caps Length Adjustment Type 2 is now at Banzai!!!
for Drift Package aluminum dampers
The aluminum shock cap capable of adjusting the vehicle height without changing the pre-tension.
Stainless steel pillow ball inserted already
New Active Hobby Items now at Banzai Hobby !!!
Pillow Ball Steering Rod Set (20 ~ 25mm & 25 ~ 30mm)
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
an comes in 4 colors
Black
Blue
Silver
Red
WR-02 / GF-01 Adjustable Upper Arm Front & Rear (20 ~ 25mm & 25 ~ 30mm)
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
Black
Blue
Silver
Red
Get in Quick as these are selling FAST!!!
Please Join us at Facebook for weekly Specials and Updates
Banzai Hobby Team
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
Black
Blue
Silver
Red
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
Black
Blue
Silver
Red
Banzai Hobby Team
New from Active Hobby
Aluminum Motor Guards for WR-02 Chassis
Protect the motor of the WR-02 chassis well and support a tough, wild run.
Aluminum Steering Wiper for GF-01 Chassis
Support to steering work of the big tire 4WD. It is a steering wiper of CNC aluminum & strong.
With Ball bearing specifications and smooth also,little clearance.
Please check us out on Facebook for weekly specials and updates
Banzai Hobby Team
Banzai Hobby Team
New From Active Hobby!!!
Piggyback Shock Cap for TRF Shock 2pcs
Aluminum shock cap with a dummy subtank matching both on road DRIFT/ off-road. It is most suitable for a dress-up.
With position of FF/FR/RF/RR indicator where you used all around for time of maintenance.
Aluminum Rear Tube Bumper for Tamiya Willy Bodies
Suitable for Tamiya Willy bodies.
Rear bumper146mm length made from 8mm in diameter aluminum pipe.
Active Hobby Matek USB Power Adapter 2.5A
USB power adapter appeared smartphone and tablet devices can be charged with a Lipo battery, etc.!
Supports DC power of 7 ~ 26V. In 2-6 cell Lipo battery and 12V car battery or the like for R / C, charge and various USB devices of smartphones and tablet devices is I can use. Leisure in the outdoors of course, also takes an active part in an emergency such as a power outage or disaster.
iPad in high-power specification of maximum 2.5A series is also possible charge.
Considering the heat dissipation, and adopted a design that takes advantage of the printed circuit board of the precursor.
Starting with lipoic cut off to prevent over-discharge, in four of protection function to prevent overvoltage Short reverse connection, input side (battery / power) also output side (smart phone, etc.) will also firmly protection.
5-mode liquid crystal display screen of, I will display the following status.
Voltage (V) - input (battery / power supply) side of the voltage-current (A) - output capacity to output (smartphone, etc.) side (mAh) - Did you power how much to the output (smartphone, etc.) side Display Total capacity at milliamps (Total mAh) - one of the one of the display time with ma total was powered much on battery (0:00:00) - The total power of the time in one of the battery
Note * connector for battery connection is not included. Please prepare separately to suit you you will use battery.
Please Join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Banzai Hobby Team
Body Mount Tower Bar Front and Rear for WR-02 / GF-01 & Willie Body System Aluminum Side Step
Body Mount Tower Bar for Tamiya TT02 / 01 F & R
Front and Rear Body Mount Tower Bar for Drift Package
For Weekly Specials and Updates please check us out on Facebook
Banzai Hobby Team
Banzai Hobby Team
