Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Yokomo DP-DIB2 DIB ver.2 Aluminium A Arm BLUE >
Old 03-28-2014, 05:48 AM
Company Representative
Arrow Yokomo DP-DIB2 DIB ver.2 Aluminium A Arm BLUE
Yokomo DIB Ver.2 now available for PRE-ORDER
Available as
Yokomo [PRE-ORDER] DP-DIB2 DIB ver.2 Aluminium A Arm BLUE
Yokomo [PRE-ORDER] DP-DIB2R DIB ver.2 Aluminium A Arm RED
NOW popular RC drift chassis Yokomo DIB available us grade up version!! DIB ver.2
DIB ver.2 include Aluminium Type A arm! You can now easily adjust the front alignment.
By using Rigid Aluminium Lower Suspension Arm & Upper Arm Bulk Head, there are more option / adjustment front and back, for Upper / Lower section. Also wheel base and caster angle can be easily set.
There are so many variable option (easily adjusted) for tread, lower arm and damper position, you can set up perfect drift set up with DIB ver.2 suspension system.
Features:
In-Line Layout Chassis
2 belt driven chassis for perfect control
Many alignment can be achieved by Aluminium Front A Arm
Front Midship Motor Layout
Full Counter Drift can be achieved with DIV ver.2 acherman ratio.
Steering Angle 45deg.
SSG Double Deck Chassis & Damper Stay
High precision aluminium motor mount
Low Friction Universal Shaft
Aluminium Oil Shock
Full Ball Bearing
BanzaiHobby is offline
