-   Banzai Hobby (https://www.rctech.net/forum/banzai-hobby-147/)
-   -   Active Hobby Burn Effect Smoke Generator (https://www.rctech.net/forum/banzai-hobby/747074-active-hobby-burn-effect-smoke-generator.html)
BanzaiHobby 07-26-2013 02:50 PM
New from Active Hobby the Burn Effect Smoke Generator is now at Banzai Hobby!!!
http://i1067.photobucket.com/albums/...psdc67c34f.jpg
It is a smoke-generating units of the electric heat that is connected to the battery for traveling, to smoke with a dedicated oil supplied. It is possible that the oil droplet 2.3, 10-15 minutes enough to generate smoke.
• The fixed with tie wraps to the machine, you can use the simple wearing only to interrupt between the ESC and the battery 2P connector provided.
Note:
※ burn effect body because it becomes very hot, the handling, pay attention enough. It may cause burns if they come into direct contact with a body that is very hot.
※ In the 10 to 15 minutes of continuous use time once, it can cause a malfunction to induce overheating If you do it more.
※ I + or pour the oil always in use, smoke once it is no longer out, please switch to OFF.
※ It becomes the cause of the failure is a state-fired empty the utility is used with out the oil.
※ generation of smoke is different in the remaining amount of the battery.
Get in QUICK as these are Selling FAST!!!
Please join us on Facebook for Weekly updates ans Specials!!!
Banzai Hobby Team
