NEW Tamiya Hop Ups!!!
New from Tamiya a Wide range of Hop-Ups now at Banzai Hobby!!!
Front Skid Angle Spacer Set - RM01 (w/4mm Titanium Screws) These spacers enable fine ground clearance and skid angle adjustments of the RM-01 chassis' front suspension, enabling a wider range of setting adjustments as well as increased suspension attachment rigidity. http://i1067.photobucket.com/albums/...ernz/54456.jpg TRF201 Sus Weight Block (0) This metal suspension block (approx. 30g) replaces the kit-standard N3 parts to help provide greater front wheel traction and increased rigidity. TRF201 Sus Weight Block (5) This metal suspension block (approx. 30g) replaces the kit-standard N3 parts to help provide greater front wheel traction and a skid angle increase of 5°. http://i1067.photobucket.com/albums/...ernz/54440.jpg Lightweight Shaft - Front-Middle Made from hard- coated aluminum, this lightweight, durable front middle shaft offers efficient power transfer and improved throttle response. It is compatible with a wide variety of pulleys to allow for creating drift settings on the TA-06 chassis. http://i1067.photobucket.com/albums/...ernz/54434.jpg Lightweight Main Shaft Made from durable aluminum, this lightweight main shaft offers efficient power transfer and improved throttle response on the TA-06 drivetrain. It also features hard coated surfaces for improved durability. http://i1067.photobucket.com/albums/...ernz/54433.jpg Steel Bevel Gears - For TA06 Gear Diff Unit Replace the kit-standard plastic gears (GV1 and GV2) with these metal gears to allow your car to handle tough driving conditions such as rally driving with a high-powered motor. Compatible with TA06, XV-01, and FF-03R chassis. Also usable with TRF417 Gear Differential Unit II (Item 42197). http://i1067.photobucket.com/albums/...ernz/54428.jpg Please Join us on Facebook for Weekly updates and Specials!!! Banzai Hobby Team |
