Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Kyosho MB-010 ASF BCS Optima With Clear Body >
Old 03-01-2012, 04:02 PM
Company Representative
Default Kyosho MB-010 ASF BCS Optima With Clear Body
Kyosho MB-010 ASF BCS Optima With Clear Body Now at Banzai Hobby
Kyosho releases this clear body version of the MINI-Z buggy in response to calls for customized body color schemes from the many fans created by the MINI-Z buggy’s dynamic performance and handling. The clear body includes a special decal set so you can create your own style of racing machine. The chassis is equipped with a shaft driven 4WD incorporating a 2-diff drive train and slipper clutch as well as 4-wheel independent double wishbone suspension supported by oil shocks. The precision design compacts sophisticated mechanics into a palmtop size chassis that delivers stunning off-road performance. Most of the advanced components are protected within a shell structure that keeps out dirt and contributes to chassis rigidity to deliver the robust performance worthy of the name ‘racing buggy’. The specially designed separate structure of the control circuit board is based on the MINI-Z Racer and tuned for optimal buggy performance. Also, an optional gyro unit can be installed, precision control settings can be made from a PC via the ICS function and Chase Mode can be activated to turn up the heat in racing (special 3-channel transmitter is required). In addition, the newly designed steering servo features 7-stage gears for precision high-torque control and the MINI-Z’s renowned linear control response and realistic steering feel. This is a great 2nd car to express your individual style.
For more info Please Click Here
Banzai Hobby Team
BanzaiHobby is offline
