Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Tamiya 84275 TA05.VII Gold Chassis Kit in Stock! >
Old 03-01-2012, 07:09 AM
Company Representative
Default Tamiya 84275 TA05.VII Gold Chassis Kit in Stock!
Tamiya 84275 TA05.VII Gold Chassis Kit now in stock!
These are limited edition and we only have limited quantity, so don't miss this opportunity!
This special variant of the TA05 ver.II comes with gold-colored anodized aluminum parts as opposed to the standard available separately blue-anodized aluminum parts.
This GOLD Chassis Kit features the following special gold-colored Option Parts:
Item 42102 TRF Special Damper (Hard Black Coating)
Item 42143 4mm Aluminum Serrated Wheel Nut
Item 53570 Clamp Type Aluminum Wheel Hub (4mm)
Item 53990 TA05 Aluminum Bulkhead
Item 54077 44mm Lightweight Rear Swing Shafts
Item 54128 TB-03D Aluminum Bumper Support
Item 54193 M-05 Aluminum Steering Post
Item 54197 TA05 ver.II Aluminum Motor Mount Set
Item 54249 3x32mm Aluminum Turnbuckle Shaft (2pcs.)
TA05 ver.II Aluminum Center Motor Plate
Other Included Option Parts:
Item 51092 TB Evolution IV 46mm Swing Shaft Item 51445 TRF417 Wheel Axle
Item 51444 TRF417 Cross Joint Set Item 54145 TB-03 EX Urethane Bumper
BanzaiHobby is offline
