Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Kawada Chassis Kit for Tamiya RM01 >
Old 02-26-2012, 04:21 PM
Company Representative
Default Kawada Chassis Kit for Tamiya RM01
The Kawada Chassis Kit for Tamiya RM01 are now at Banzai Hobby
The Chassis is is a great way to upgrade from the Plastic chassis to FRP or Carbon with high Quality Alloy motor mount
[Technical data] chassis
■ / front width / 275mm ■ Length: 160mm Rear: 164mm ■ tread / front: 135.6mm Rear: 134mm ■ Wheelbase when traveling / 210mm ■ / ball diff format / 1050g (6cell) ■ Def gross weight / direct drive format (Shaft) ■ duralumin shaving: independent rear suspension: / front right suspension format drive ■ / ■ full ball bearing motor mount / bearing unit ■ (sold separately) ■ motor variable front caster type ■ Connect / / 540 type trees: High rigidity left
※ RC equipment products, batteries, motors, tires, wheels are not included.
For more info Please Click Here
Banzai Hobby Team
BanzaiHobby is offline
