Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Tamiya Street Rover - DT02 >
Old 02-26-2012, 02:02 PM
Company Representative
Thumbs up Tamiya Street Rover - DT02
The new Tamiya Street Rover - DT02 is now at Banzai Hobby
The Street Rover is an on-road variant to item 58500 Sand Rover 2011. It is equipped with wide on-road tires for extreme street performance.
Tech Note:
The Tamiya Sand Rover is designed for the novice builder and driver. The front wheels are oversized for stability and easy driving. Make sure to turn down the transmitters steering "dual rate" to ensure maximum lock is not possible. Maximum "dual rate" will cause the steering linkage to touch the inside front wheel. By turning down the transmitters "dual rate" you will insure the steering linkage will not touch the front inside wheel no matter how much steering input is given while driving.
Specs and Features
1/10 scale R/C assembly kit.
Resin body is pre-painted in Candy Lime Green (Equivalent to Tamiya Color TS-52).
DT-02 chassis: 4-wheel independent suspension with coil spring dampers.
380 motor included
Includes 1150 Ball Bearings x 14pcs.
Fully-enclosed gearbox protects against dirt and debris.
Wide-tread on-road tires are mounted on sliver-plated wheels.
Semi-finished driver figure also included.
For more info Please Click Here
Banzai Hobby Team
BanzaiHobby is offline
