Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Yokomo DP-DIB Drift Package DIB >
Old 02-20-2012, 05:49 PM
Company Representative
Default Yokomo DP-DIB Drift Package DIB
Available around 29th Feb 2012
Please make sure to sign up with back in stock notification if you do not want to miss the item!!
NEW Drift Machine from Yokomo.
Using inline layout (by putting weight on middle of chassis) will create superb handling and balance. By using narrower SSG main chassis and resin bulkhead, it will create smooth yet perfect traction for side way drift action. It can be used with short size Li-Po battery and front / rear balance can be adjusted offering you many range of setting. Check out steering angle for perfect drifting and perfect match with FCD pulley.
Features:
* Inline layout design
* 2 belt drive for perfect drift control
* Front Midship Motor layout
* Full Counter Drift
* Steering Angle, 45deg
* Front One Way & Rear Solid Axle
* SSG Double Deck Chassis
* SSG F&R Damper Stay
* High precision Aluminium Motor Mount
* Low Friction Universal Shaft (F&R)
* Aluminium Oil Suspension
* Full Ball Bearing
Check out Yokomo DP-DIB Drift Package DIB photos, price and sign up with in stock notification now!
BanzaiHobby is offline
Old 02-22-2012, 02:35 AM
(Date is estimate only)
Due to high demand, we have open up the order. If you place an order now, we will send Yokomo DIB for you as soon as we receive the products.
*First in, First served. *
Only limited quantity available so secure your order now!!!
