Kyosho New Line Up
A New Line up from Kyosho is now at Banzai Hobby
MR-03W-MM BCS RAYBRIG HSV010 2010
<Content of the body >
● Semi-finished chassis comes with front body mount ●, ● MM Power Unit Specifications Fully assembled plastic body markings (already built).
● wide tread (front) lower and upper plates, steering tie rod (already built).
Narrow ● Tread (front) lower and upper plates, steering tie rod (included)
● Front Suspension adjustment spacers
● 6T · 7T · 8T · 9T pinion gear
● Wheel Wrench
● Remove the pinion tool
● Stick Pair
● Spare wheel nut
● Accessories Tires Wheels
For more info Please Click Here
ARTA HSV-010 2010 Body
<Fits>
■ MINI-Z MR-03W-MM
<Specifications>
■ Wheel Base: LL (98mm)
■ Wheel Off Set: F: 2.0mm / R: 2.0mm
■ Wheel Width: F: 8.5mm (N) / R: 11mm (W)
■ White Body No.: MZN130
■ F. Body Mount No.: MZN130-2
Carbon Aero Blue Mazda RX-7FC
■ MINI-Z MA-010
<Specifications>
■ Wheel Base: M (90mm)
■ Wheel Off Set: F: 1.0mm / R: 1.0mm
■ Wheel Width: F: 8.5mm (N) / R: 8.5mm (N)
■ Wheel No.: MDH012SB
■ White Body No.: MZN102
■ F. Body Mount No.: MZB39-2
Kyosho new Transmitters
PERFEX KT-18 (2.4GHz) Transmitter
This is the Kyosho Perfex KT-18 2 Channel 2.4GHz Transmitter, and is intended for use with Kyosho Mini-Z and dNaNo vehicles.
Perfex EX-5UR ASF 2.4GHz 3 Channel Transmitter
This is the Kyosho Perfex EX-5UR ASF 2.4GHz 3 Channel Transmitter. The EX-5UR adopts the ASF 2.4GHz technology, boasting the fastest response among Mini-Z radios. Easy set up with 4 buttons and an LCD screen, while 27 kinds of ready-to-race functions provide capability of very advanced settings that can be stored in 7 memory slots. The Red Limited Edition is equipped with a push-and-return 3rd channel switch suitable for the Mini-Z Chase Mode overtake button feature, so you don't need to pull back the switch after using the overtake boost allowing you to concentrate on steering and throttle control.
Get in Quick as these are Selling FAST !!!!!
Banzai Hobby Team
● Wheel Wrench
● Stick Pair
● Spare wheel nut
<Fits>
■ MINI-Z MR-03W-MM
<Specifications>
■ MINI-Z MA-010
<Specifications>
Banzai Hobby Team
