Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Yokomo B-Max4 II in Stock! >
Old 05-03-2011, 10:55 PM
Company Representative
Default Yokomo B-Max4 II in Stock!
Yokomo B-Max42
B-Max4 II Chassis Kit
Affordable yet expert can still enjoy B-Max4 II!
Newly designed forward cabin new body.
> More down force and shifting weight towards front
> Capable of more aggressive cornering
Newly designed wing
> High down force type
> More stable
Features:
* Easy to maintain shaft drive full time 4WD chassis
* Centered Motor > perfect balance
* Universal Center Shaft
* Full adjustable double wishbone suspension
* Large Oil Damper Suspenson
* Full adjustable spring tensioner (Dial type)
* Front & Rear ball differential gear
* Front & Rear universal shaft
* Die Cast Clump type motor mount
* Variable adjustable slipper clutch
* Front aluminium sus-mount brace
* Full Ball bearing
* Separate pack battery & Cell type batteries can be used
* Newly designed forward cabin type body
Chassis Spec:
Length: 390mm
Width: 247mm
Height: 145mm
Wheel Base: 279mm
Tread: F/218mm R/207mm
Weight: Approx 1880g
BanzaiHobby is offline
