Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
TN Racing : TN-680 Drift Package C-Max Conversion Kit!! >
Old 04-06-2011, 10:49 PM
Company Representative
Arrow TN Racing : TN-680 Drift Package C-Max Conversion Kit!!
Now open for Order!
Convert your Yokomo Drift Package into D-Max Style high end drift machine!
Features:
* Separate Battery style and shifting weight to rear end > more stability for drifting!
* Using Aluminium front and rear born > More pitching!
* Reversible Motor and Servo/ESC lay out! Set up with your preference!
* Battery position can be adjusted by 6mm to front and rear. If using heavy battery, you can shift to front, light battery to the rear etc. You can now set up the perfect balance! Especially ideal on low grip surface.
* Newly designed steering wiper post! Now you can adjust the bump steer amount.
* Newly designed aluminium motor mount, aluminium cneter bulkhead enhance low gravity and rigidity.
* Using 1150 size bearing for center input shaft means longer life!
* Easy maintenance! In order to change spur gear, you only need to undo 5 screws!
* Rear end is designed with D-Bar (like T-bar). This design will enhance kicking of rear end pushing front end forward. Pitching will be adjusted with torque rod and roll direction will be adjusted with rear bone.
* Super light weight! Approx 100g lighter compare to Yokomo Drift Package.
* Many hop-up parts will be available from TN-Racing for C-Max!
You require following parts to make complete.
Tires
Wheels
Motor
Battery
Radio Gears with ESC and Servo etc.
If you have running Yokomo drift package, you do not need any other extra parts for the conversion!
Check it out!!
http://banzaihobby.com/index.php?mai...ducts_id=10485
BanzaiHobby is offline
