Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Yokomo Drift Package Mini RTR 2.4ghz Series *Now in Stock* >
Old 01-04-2011, 02:41 AM
Company Representative
Default Yokomo Drift Package Mini RTR 2.4ghz Series *Now in Stock*
We now have Yokomo Drift Package Mini (1/15th Scale) RTR 2.4ghz at Banzai Hobby!!!
Using Yokomo RC Drift knowledge, they now have released Mini Size Drift Package!! Highly detailed body just like Yokomo Drift Pacakge series and using rigid axle shaft drive full time 4wd, this mini drift package will slide side way with no sweat. Whether you want to drift indoor or outdoor, you can take Drift Package Mini with you everywhere!
This is RTR (Ready to Run) package and yeahp, it comes with 2.4Ghz Radio Gears! (so you do not have to worry about crystals.)
Great value!
Features:
* F&R Rigid Axle Shaft Drive Full Time 4WD
* 4 Wheel Double Wishbone Suspension System
* Drive train has protector to prevent sands and grits to come in
* Completed Body (light weight polycarbonate)
* F & R Universal Shaft
* 2.4Ghz 2ch Transmitter / Receiver
* 1400mAh Mini Size Ni-MH Battery
* AC Type Battery Charger (100V-240V): (you may require adapter for your country)
Overall great value packed in mini size drift rc and loads of fun without compromising Yokomo RC Drift quality!
Yokomo Drift Package Mini Line-Up:
Yokomo DPF-JZZ30 Drift Package Mini Vertex Ridge TE3006 Soarer
Yokomo DPF-IS220 Drift Package Mini HKS IS-220R ALTEZZA
Yokomo DPF-JZX Drift Package Mini Kunny'z JZX100 Chaser
Yokomo DPF-ORCZ33 Drift Package Mini ORC with TOPSECRET Z33
Yokomo DPF-JZX90 Drift Package Mini Toyota JZX90 Mark2
BanzaiHobby is offline
