Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Square SVD-100 TA05-VDF Counter Drift Pulley Set >
Old 12-16-2010, 06:29 AM
Company Representative
Default Square SVD-100 TA05-VDF Counter Drift Pulley Set
Square SVD-100
This Square SVD-100 Tamiya TA05-VDF Counter Drift Pulley Set
is to achieve counter drifting with your TA05-VDF easily by changing front and rear driving ratio.
Further more, you can adjust and experiment different ratio using different pulley set up to optimize your drifting!!
Kit include:
Center Pulley 18, 20, 22T (STA218 - 222)
Front Ball Diff Pulley 40T (STA-240)
1 Way & Rigid Diff Pulley 40T (STA-102)
Aluminium Rear Diff Pulley 30T (SVD-330)
Front Belt 225-75T (SVD-175F)
Rear Belt 471-157T (SVD-157R)
May require modification depending on the pulley matching.
Require Tensioner if you are using 22T
BanzaiHobby is offline
