Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Yokomo Team Suzuki Real Caliper Set at Banzai Hobby >
Old 08-03-2010, 07:42 AM
Company Representative
Default Yokomo Team Suzuki Real Caliper Set at Banzai Hobby
These Caliper Set can be fitted with Yokomo Drift Package Series Chassis. Using specially designed Front Knuckle/ rear hub carrier, Calipers (Highly detailed 6 Pod Calipers) are fixed on to Front knuckle arm / rear hub and only brake disc rotates around. Just like a real drift machine!!
Pimp up your RC Drifter!!
You can choose from Red, Blue and Gold
Check it out!!
http://banzaihobby.com/index.php?mai...ort=20a&page=7
You can adjust the tread by purchasing Yokomo TS-2113 2mm width and Yokomo TS-2144 4mm width.
BanzaiHobby is offline
