Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Hitech Multi Charger x4 >
Old 07-25-2010, 07:50 PM
Company Representative
Default Hitech Multi Charger x4
If you are looking for serious battery charger, this is your opportunity!!
http://banzaihobby.com/index.php?mai...oducts_id=8434
With HiTec Multi Charger, you can combine any kind of batteries to charge or discharge up to 4 batteries in same time!
For example, you can charge Lipo and Life battery while you are discharging NiMH and Nicd Battery!!
Features:
* Charging & Discharging for 6 different type of batteries
* Cycle charging and discharging capability (NiMH, Nicd)
* Balance charging and discharging capability (Lipo, Life, Li-ION)
* Storage System (Lipo, Life, Li-ION)
* Show each cell voltage (Lipo, Life, Li-ION)
* Safety Timer System
* Setting Data Save Mode
* Alarm System (for voltage set up mistake, wrong connection etc.)
* Safety System (Monitor the power source voltage etc)
Batteries:
Capable of charging / discharging following batteries:
* Lipo
* Life
* Li-ION
* Nicd
* NiMH
* Pb
Cells:
* Li-Po/Li-Fe: 1-6 Cells
* NiMH/Nicd: 1-15 Cells
* Pb: 2-20V
Charging Rate:
0.1 - 6.0A (Max 50W per port/Max 200W per charger)
Discharging Rate:
0.1 - 1.0A (Max 5W per port/Max 20W per charger)
Balance Connector: Multiplex, Thunder Power, Flight Power
Dimension: 225.4 x 158.6 x 62.4mm
Weight: 1.09kg
Input: DC11-15V
Set Include Following:
* Charger
* Battery Clump
* Traxxas Type Connector
* Tamiya Type Connector
* 2Pin / Deans Type Connector
* Multiplex Type Connector,
* RX Battery Connector
* Alligator Type Connector
* Balance Board (Multiples, TP, FP Type) x 2
BanzaiHobby is offline
Old 08-12-2010, 10:58 PM
If it came with AC/DC 220V input it would get my vote and order, but the need for an additional strong power supply is a huge negative...
lomdel is offline
