-   Banzai Hobby (https://www.rctech.net/forum/banzai-hobby-147/)
-   -   Yokomo Drift Package Plus Type-C (https://www.rctech.net/forum/banzai-hobby/393138-yokomo-drift-package-plus-type-c.html)
BanzaiHobby 04-27-2010 06:11 AM
Yokomo Drift Package PLUS Type-C main feature is comes with Full Adjustable Type A Arm Double Wishbone Suspension!!
http://banzaihobby.com/images/Yokomo...rand=150261500
Type A Arms are designed smaller meaning more clearance and does not affect with large alignment.
http://banzaihobby.com/images/Yokomo...rand=348444949
By moving Spacer inside the Upper Arm, you can adjust Caster Angle between 4 - 7 degrees.
http://banzaihobby.com/images/Yokomo...rand=294216289
Tread can be freely adjusted by Upper Arm, Lower Arm and Universal Shaft Setting.
Front and Rear Suspension Arms are now sharing same parts for easy maintenance.
Toe-In angle can be easily adjusted by tie-rod. (Rear Knuckle)
Include front and rear universal shaft!
Include Lipo Battery Plate!
http://banzaihobby.com/images/Yokomo...rand=317894633
One Touch Damper Pivot
Features:
* High efficient shaft drive full time 4WD system (inc gear cover dust protector)
* Fully adjustable type A arm Double Wishbone Suspension
* Large Aluminium Oil Damper Suspension
* Blue Center Shaft
* F & R Universal Shaft
* Aluminum Diff Joint Ring
* Aluminum Diecast Clamp Type Motor Mount
