Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
TRG Dual Roll Damper Unit for Tamiya F104 >
Old 04-02-2010, 01:15 AM
Company Representative
Default TRG Dual Roll Damper Unit for Tamiya F104
TRG5097
TRG Dual Roll Damper Unit has been proved with TRG109 Chassis. Friction Roll Tube Type, Clank Type Double Roll Damper Unit.
Main features of these damper suspension unit is that you can control both pitching and roll separately to the damper suspension. This will enable wide range of settings for the suspension and achieve smooth riding, better traction for rear tires which you could not achieved with friction pads.
Further more, you can attach these straight on to F104 Normal Upper Plate and Motor Mount and you are ready to Win!!
Check it out!!
http://banzaihobby.com/index.php?mai...oducts_id=7776
BanzaiHobby is offline
Old 07-12-2010, 07:00 PM
dsyed1's Avatar
has anyone used this on the f104... any comments?
dsyed1 is offline
Old 07-18-2010, 12:45 PM
kmas's Avatar
Trader Rating: 72 (100%+)
when will this be available?
kmas is offline
