Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Active Hobby TT-01 Drift Front Midship Conversion Kit >
Old 03-30-2010, 04:03 PM
Company Representative
Default Active Hobby TT-01 Drift Front Midship Conversion Kit
Active Hobby Tamiya TT-01 Front Midship Drift Conversion Kit at Banzai Hobby
Take your TT-01 to Max with Active Hobby TT-01 Front Midship Conversion Kit!
Enjoy the "high end model" of drifting with your TT-01!
With Active Hobby TT-01 Front Midship Conversion Kit, Motor and Battery is located towards front. Achieve perfect weight balance for drifting. Easy Counter Drifting!
Features:
* Using Silver Carbon in order to get best balance weight as well as flexibility.
* Chassis shape has been modified in order to change chassis role.
* Number of Rear Post Holes has been increased in order to increase setting.
* Motor Mount has been located to Font Middle end for better weight balance for drifting and easy steering.
* Aluminium Motor mount has been designed with easy maintenance in mind.
* You can equip with TA05-Ver.II Suspension Mount as well as Short Reverse Suspension System.
Set Include Following:
* Carbon Composit FRP Support Plate (2.5mm)
* Carcon Copmpsit FRP Front Upper Plate (2.5mm)
* Carbon Composit FRT Steering Plate L&R (2.5mm)
* Aluminium Crank Lever L&R (Tamiya Blue)
* Aluminium Servo Stay (Tamiya Blue) x 2
* Aluminium Spacer (Tamiya Blue) x 8
* Steering Linkage SUS Rod Set
* Steel Hex Ball (5mm) x 8
* Ball End Cap x 8
* Steering Crank Bearing x 4
* Hex Screw, Nut, Washer
Require Tamiya 51319 if you are using on TT-01, TT-01R
Check it out at Banzai Hobby!!
BanzaiHobby is offline
