Square TA05 Drift Conversion SP Type S
Square TA05 Drift Conversion SP Type S at Banzai Hobby!
Popular TA05 Drift Conversion SP Kit has been renewal with flexible chassis & affordable price! http://banzaihobby.com/images/sdc102.jpg?rand=822880553 Features: * Using Silver Carbon in order to get best balance weight as well as flexibility. * Chassis shape has been modified in order to change chassis role. * Number of Rear Post Holes has been increased in order to increase setting. * Motor Mount has been located to Font Middle end for better weight balance for drifting and easy steering. * Aluminium Motor mount has been designed with easy maintenance in mind. * You can equip with TA05-Ver.II Suspension Mount as well as Short Reverse Suspension System. Set Include Following: * 2.5mm Main Carbon Chassis * 2mm Carbon Upper Deck * Aluminium Motor Mount * Aluminium Motor Mount Support * Aluminium Spur Gear Holder * Aluminium Steering Crank * Aluminium Belt Tensioner * Stainless Servo Rod * Rear Belt 163T * Front Belt 70T * Aluminium Steering Plate * Resin Battery Holder |
| All times are GMT -7. It is currently 07:06 PM. |
