Go Back  R/C Tech Forums > Commercial/Retail Forums > Banggood.com
TLR22 3.0 mid motor 2WD electric SUV >
Old 11-10-2015, 02:42 AM
Banggood's Avatar
Cool TLR22 3.0 mid motor 2WD electric SUV
Hi, RCTECH guys,
Team Losi Racing (TLR) release 22 3.0 rear motor (mid motor) 2WD 1/10 electric buggy. 3.0 car allows players to find the right venue rider set quickly, without too many parameters change.
New 3-gear transmission, optimized motor mounting position so that the differential between the motor and reduces the 12mm distance space, thereby increasing the rear grip and easier to drive. The new chassis cut, reducing unnecessary twisting frame, lifting the car running stability.
Players can also put four riders gear, especially for use in low grip track. Widening of 2.5mm thickness plate, support split and short body lithium battery, weight distribution is more ideal. Suspension assembly mounting holes have also been optimized, and strive to enhance the performance curves and jumps.
Ti-CN coating suspension pivot, large limited-slip differential, a large number of factory upgrades are included in the product.
Hava a good day,
Doris Lee
Banggood is offline
