Nosram setup procedure
Hey,
some one out there has to have a nosram ESC could you post the radio setup procedure, the one for the patriot reverse is what i want or even any other nosram as they should all be the same Cheers |
Switch transmitter on >> Set transmiter throttle to neutral >> Connect
speed control to battery and switch speed control on >> Hold setup button in for 3 seconds >> LED now flashes red/green to confirm it is in setup mode >> Leavethrottle stick at neutral and press the setup button >> The neutral setting is now stored, LED flashes green >> Move throttle to full and press setup button while still holding full throttle >> Full throttle is now stored, LED flashes red >> Move throttle to full brake and press setup button while still holding full brake >> The brake is now stored, LED goes out. I hope that is easy enough to read for you,goodluck |
| All times are GMT -7. It is currently 06:58 AM. |
