Lipo battery lifespan
Hi
Newbie question regarding the lifespan of lipo batteries. I have two 4s hard case batteries I use in EP buggy, one is 2 months old and the other is 3 months old both batteries are swollen and have cracked cases and have fluid leaking from them. Is this normal? I balance charge them before use and storage charge when I'm not using them. I realise Ep buggy is hard on batteries with jumps and rough surfaces but at $130 each it seems wrong to have to replace them so soon.
I have an LRP 110c Shorty pack that appears to have developed a 'clunk'. Almost as if the cells are slightly loose within the case. Has anyone else experience this? Should I be worried or looking at warranty? Pack has less than 10 runs and hang been dropped or anything.
I had some cheap (Prosonix 4s 5200 60c Lipos $45 each) that I bought 3 1/2 years ago, only charged them before a race meet on balance, at the meet they only got charged, not balanced. They were never storage charged and would sometimes go 2-3 months without charging. They still work very well and I have just put them in my nitro starter box! I will say that I charged them softly, i.e. at about 2 to 3.5 amps, Others would charge them at 5+amps and never got a long life out of them.
I think your charger and the software that it uses has a lot to do with battery life and capacity as well. I have charged a battery on one charger, on balance, taken that battery off when it was finished (or so the charger said!) Then put it on another charger on balance again and got another 400mah into it!!!!
I am fairly new to this hobby but have spent quite a bit of time sorting my battery problems...
Do the batteries get hot during discharge (car runs) ?
Do they get hot during charge ?
Does your ESC have a low voltage cut out ? Do you set it high enough ? I use 3.5V. With 4x cells there is more danger of out of balance discharge and going below 3V on a cell - this will damage the cell.
Did you check the battery voltage whilst storage charge (I mean battery across each cell - you have 4x) about 3.8V
Do you check battery voltage during ballance charge (across each battery cell) ? no more than 4.2V
The 2x items above need to be done only once - just to confirm the charger is not damaging your batteries.
Lastly - did you choose a good brand of battery ?
RGDS Joe
RGDS Joe
