best servo?/best discharger?
#16
Originally Posted by aus jd 2703
opinions on KO PDS-2123FET servo the specs are pretty good but are ko servo's good quality?
#17
Originally Posted by The Fuhrer
aus jd 2703,
Where are you getting the servos so cheap? Can you PM me the place?
The servo will work with an AM radio.
Flysti,
The JR DZ9000S will throw:.06/60 degrees @ 6V
The Futaba S9254 will throw:.06/60 degrees @ 6V
Seems everyones catching up to Sanwa/Airtronics
Flysti,
I've had the JR DZ9000S for 2 years now and still going strong...Actually the JR has more torque than any other servo in that speed ratio of 0.06.
JR all the way if you want the best outright speed with torque.
#19
aus jd 2703,
KO, Sanwa/Airtronics, JR, Futaba, are the among, if not the best producers of servos in the world.
Look at what the worlds best use, it sure 'aint Hi Tec
also have a look at the ace digitals (the all alloy case ones) i reckon they are pretty good, the 1013 (.10sec and 13kg @ 6v) is a pretty hot item and the $$ at retail in aust is very reasonable
i would not say either these brands are outright the 'best' (my $$ is with ko) but at their price are really good value, lets say you can get 2 ace's for one ko, the ko is probably not twice as good or reliable (maybe the alloy case ace might be a bit on the heavy side for TC but that may also help balance the car too)
this is one of those silly "which is best" questions which is too open ended to get a real answer... your better adding a price which is the best over $200 is different to the one thats best under $150
#20
Good point Contact,
I had a drama with a Hitec radio at last years nats.........
I have used and abused 2 Hitec HS925's over 3 years with no hiccups.
Compared to a KO 2343 there is no comparison, at all.
Price wise, seems that the 'high end' servo prices have fallen somewhat in the last couple of years as well. Hence, new KO servos.
Cheers
Cheers
#22
you seem like you have made up your mind about the servo (sanwa wrx) so i would stick with that.
the smart tray is a good unit but you may pay around 180.00 for one new in oz, unless of course you can pick one up second hand.
still nothing thats on the market at the moment will come close to a teamwave lightning.
i would also advise not to by a discharger with a cut off at only zero volts especialy if you are going to be using IB (intellect) cells.
#23
You can never go wrong with the novak equalizing tray. I've got 3 of them :P
#24
will one novak discharger be enough for a single car set up?? i run 4 rounds a night and usually just repeak my batts for the first 3 and then the main i used a freshly charged pack i think ill step my charge rate up to 6 amps next time i charge my packs opinions? how do you guy have a pack charged for every rounds when there about 30min apart??
#25
i like the s9550 for electric cars and for nitro i recon the bomb servo is the sanwa erg vx, massive torque.
best discharger? for ib's? either smarttray, team wave, or the new much more CTX-D that is comming out looks sweet as!
