grub screw removal
grub screw removal
hey there does anyone have any tips or thoughts on removing a grub screw that is rounded out from a pinion gear... it has tamiya screw glue(blue stuff) on it but that shouldn't make it too much harder.. not sure if rapid heating of pinion will expand it enough to pull it off
would using a socket head screw instead of a grub screw cause too much inbalance.. atleast with these you can put vice grips on to remove..
If you have no other option, or don't care about ruining the pinion you could just drill it out.
Left hand threaded drill bits are available, which might back the screw out as you drill. But wouldn't be worth buying a set just for this though.
If it's a metric screw, I'd be trying a 1/16th hex driver first.
