Ask Ray Munday - JConcepts, Reedy, Associated Aussie Support Thread
#1396
B6.1D Setups
Hi guys, I have been working on some starting setups for the B6.1D outdoors. Ive tested standup 3 and 4 gear, standup shocks forward, and layback shocks rear. Here are a few setups to get you going. Ill be updating these as we do more testing
#1397
hi there ray thankyou for posting the setups.im really happy with the b6.1d. i noticed your running the ally rear hubs in your setup . what is the equivalent hole in the stock kit hubs?
#1398
Hi Ray,
Thanks for your great thread.
Returning to RC with a B6D.
Will be running Stock 17.5 with 4 Gear Stand Up......any Spec Sheets that would get me dialled in at St Ives track in NSW?
thanks!
thanks!
#1400
Id suggest using this as a starting point:
Team Associated B6D - Ray Munday - Keilor Cup - 16-17.12.2017
If the grip is low, use the 25g brass C block (needs some dremelling to fit the standup). This gives a lot more rear grip. The B5R rear arms make the wheelbase 2mm shorter, this really helps as well. Any questions let me know.
Ray
#1401
Hi Ray
curious to know if you've done a setup guide for the B64D, like you did for the B6 (and B5)?
many thanks
Simon
many thanks
Simon
#1402
Hi Simon,
I haven't made the same guide as i don't tend to change as much on the 4wd. However i have listed the latest setup ive been using on the b64 here:
https://m.facebook.com/story.php?sto...96568894020064
Hope it helps!!
Ray
Hope it helps!!
Ray
#1403
another question, this time about LRC vs HRC A + B blocks. I bought a club car which comes with HRC blocks for some reason. Neither of the other kits come this way so I'm wondering why, and what effect this might have on the car
thanks
S
#1404
Hi ray are the b5 front axles the same as the b6 ones except made out of steel instead of aluminium?
#1406
TBH Im not sure why they are included in the club car.
Ray
#1407
Hi mate, sorry for slow response. The HRC front blocks are not something I have run. A high roll centre on the front can make the car feel a little darty then push mid corner. To compensate, I would run the front axle at 0mm height instead of +1mm, and I would use no washers on the outer front link. Add 1mm bumpsteer washer. The overall feeling should be similar.
Ray
Ray
S
#1408
Hello Mr Munday
hope all is well mate.
I just built a b6.1D and have an sc6.1 on its way soon.
The where the buggys shocks mount to the tower - was very sloppy! How did you remedy this?
#1409
Hope you enjoy driving the car and the SC6.1!!
Ray
#1410
Hi, on my kits the vertical play is minimal. There is some play forwards / backwards, but this does not change the suspension movement as it is 90deg to the suspension operation. You can reduce that using washers or an o-ring but if there is any binding it will hinder the suspension free movement.
Ray
Ray
yeah the the movement is horizontal. I found it very odd. Will get a vid and pm you on fb Tonight.
thank you
