Speed passion 2.0 pro esc help
Hay all.
Im new to running sensored esc and motors. im just looking for some clarification and descriptions of some of the terms in my esc settings. See Pic below. I really need a description:
1. Boost timing
2. Turbo open time
3. Turbo timing
4. Boost start rpm
5. Turbo open delay
6. Boost timing acc
I read the instructions but still dont completely understand. Thanks for your help
cheers josh
1. Boost timing
2. Turbo open time
3. Turbo timing
4. Boost start rpm
5. Turbo open delay
6. Boost timing acc
cheers josh
Plenty of info in the EP section
Here is a link to the manual, explaining what is what!! Hope this helps you....
http://www.hobbywing.com/product_show.asp?id=218
Hay all.
1. Boost timing
2. Turbo open time
3. Turbo timing
4. Boost start rpm
5. Turbo open delay
6. Boost timing acc
cheers josh
1. Boost timing
2. Turbo open time
3. Turbo timing
4. Boost start rpm
5. Turbo open delay
6. Boost timing acc
cheers josh
Boost start rpm tells you at what rpm you start getting extra boost timing. Boost timing acc is the rate at which you get extra timing after the boost start rpm, eg 1 degree for every 500 rpm.
Turbo timing is the maximum extra timing you get from turbo. Turbo open delay the time (in seconds) after you hit full throttle before the turbo timing engages. And I'm not sure about turbo open time, that might be new for version 2.
i couldnt find any relative info on the website. i went to programmable items but it was blank.
ok so boost is like the standard timing for a sensorless esc, and turbo is like your normal turbo in a car(only kicks in when rpm is high enough).
is boost start rpm and boost timing acc for my turbo or standard timing?
slightly confused still but slowly getting it
Boost works all the time. Turbo only works on full throttle. Boost timing is the maximum extra timing you get from boost.
your boost is your boost. so start RPM is for boost, as well as ACC.
Turbo is controlled by full throttle signal. so delay is set to when you want turbo to work after it seeing full throttle. less delay means it will come on quicker after you have pulled full throttle.
your turbo open time is how agressive you want the turbo applied.
ACC is the setting as to how agressive you want the boost applied.
