Sensor cable and battery question
Hi,
Are sensor cables generic? or particular to motor / esc What is the relationship between the battery and the ESC (Amps) and how is that calculated? 6800 70C 7.4v = ??Amps, if ESC = 45A, burst = 260A, does that imply a battery no bigger than 4500MaH and what ??C Thanks |
Originally Posted by bitisbitis
(Post 10216537)
Hi,
Are sensor cables generic? or particular to motor / esc thanks |
As far as i'm aware they are generic.
Bump on the battery question.
(Post 10218310)
when working out the 8th scale gear i have, i was informed of Amps, x C rating and it should out rate the Running Amps of the speedy, this is to not have the battery as the weak link. but burst Amps is all different. a 40C battery cant really meet the demands of Runnign a lot of turbo or very agressive software. you will soon see the battery over heat, and Puff. i have seen the Orion 90C batteries Puff in Mod, and it really comes down to how you look after your batteries and how much demand you want from them. If you want all out performance, then you will push all your gear to its limit, and probably past it, then things just dont last. if your happy to take things easier, then your stuff will last, but you cant expect the same performance from some one pushing things to the limits. |
(Post 10216537)
Hi,
Are sensor cables generic? or particular to motor / esc What is the relationship between the battery and the ESC (Amps) and how is that calculated? 6800 70C 7.4v = ??Amps, if ESC = 45A, burst = 260A, does that imply a battery no bigger than 4500MaH and what ??C Thanks http://www.geelongrcoffroaders.com.a...9.html#msg6349 |
| All times are GMT -7. It is currently 02:52 AM. |
