-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Aarcmcc Rules (https://www.rctech.net/forum/australian-racing/5421-aarcmcc-rules.html)
TrustMe 05-25-2002 01:39 AM
Aarcmcc Rules
I would be interested to find out what racers views are on current rules, and would like to have some feed back on what rules may be changed to improve the running of sanctioned and non sanctioned events.
David 05-25-2002 04:35 AM
Re: Aarcmcc Rules
Anthony do you have link to the current regs? i had a bit of a surf around and couldnt find them :blush:
TrustMe 05-25-2002 07:23 PM
David send me you e-mail address and I'll send you the current updated rules.
A.G
TrustMe 05-26-2002 09:06 AM
CURRENT AARCMCC IC RULES.
These rules must be read in conjunction with the General Rules
1. 1/8th IC ON-ROAD TECHNICAL SPECIFICATIONS
1.1 The engine may have a total capacity of not more than 3.5 cubic centimetres/0.214 cubic inches. No tolerance allowed. Each individual car must not produce more than 85 decibels, measured at ten (10) metres distance and one (1) metre high at full throttle. AARCMCC definition of a noise level is always final.
1.2 The fuel tank, including filter and fuel pipes up to the carburettor may hold a maximum of 125 millilitres/4.23 fluid ounces. No loose inserts allowed. Any tank found to be illegal (over 125 millilitres/4.23 fluid ounces) after a heat or final shall be removed from the car and inspected for a second time after an initial ‘cool down’ period of fifteen (15) minutes. This ‘cool down’ period is only necessary in the case of temperatures above 20 degrees C / 68 degrees F.
1.3: Overall dimensions:
Wheel base 270 - 330 mm/11-13 in.
Maximum overall width 267 mm/10.5 in.
Maximum overall height 190 mm/7.5 in. (except aerial)
1.4 Tyres:
Maximum width front 37 mm/1.5 in.
Maximum width rear 64 mm/2.5 in.
Tyres must be black, except for writing on sidewalls.
1.5 Rims: The rim's diameter must not exceed 54 mm/2.1259 in. An edge to reinforce the rim of 2-mm/0.0787 in. thickness and 3-mm/0.1181 in. height on the inside (car side) is allowed. Flange diameter maximum 60 mm/2.3622 in. Any fixing bolts or other equipment installed in the wheel rim must not extend beyond the exterior of the wheel rim. The wheel rim must not extend more than 1.5 mm/0.059 in. from the exterior of the tyre.
1.6 All cars will be equipped with brakes and a clutch in such a manner that the car may be held stationary with the engine running.
1.7 Only IFMAR homologated pipes are allowed. The pipes used on the car have to bear their homologation number during the entire championship and their measurements (both internally and externally) have to conform to those on the homologation sheet issued by IFMAR.
The IFMAR Approved Muffler List, with detailed drawings, must be available in Technical Control. Additional copies of the IFMAR Approved Muffler List must be available to each participant, if requested.
The outlet or tailpipe of the muffler must project horizontally or downward. No upward or vertical exhaust outlets are allowed.
The first cone on all homologated mufflers may be reduced by a maximum of 8-mm./0.31 in. (length). The outlet pipe may have a minus tolerance of 2-mm/0.078 in. (length).
1.8 The front of the car must be equipped with a bumper in such a manner that it will minimise a wound in the case of it entering into contact with other participants or members of the public. The bumper must be made from a flexible material with all corners and sharp edges rounded off. The contour of the bumper will follow the contour of the body with which it is being used. At no point may the bumper protrude more than 5 mm/0.20 in. in front of the body.
1.9 If a rear bumper is fitted, it must finish no more than 10 mm/0.40 in. behind the rear wheels.
1.10 If a rollover bar is built in, it must be placed behind the driver or just behind the imaginary driver’s position.
1.11 The aerial must be made from a flexible material in such a manner that it will bend completely under the weight of an inverted car. Metallic aerials must have the free end protected.
1.12 Bodies must be a one-eighth scale authentic reproduction of sports cars or prototype cars in full scale racing participating in FISA's, IMSA's or CANAM's official sport classes. There will be an allowance of 10% tolerance in all dimensions.
1.13 Only bodies that are recognised and approved by IFMAR will be allowed.
1.14 The body must be made from a flexible material and painted properly.
1.15 A realistic driver's figure (minimum helmet and shoulders) made to l/8th scale and painted in a minimum of three (3) colours must be fixed at the normal place in the body. The head may not be amputated to make way for the fuel filler cap or any other element. The driver need not be fitted under a closed body.
1.16 All bodies must have the front and rear sides cut out for the wheels if the original was so designed. The radius of the cutout must not exceed the tyre by more than 13 mm/0.5 in
1.17 The windscreen must not be cut out. In closed bodies, a hole of maximum 6.5 square centimetres/1 square inch for cooling is allowed to be cut out in the front of the windscreen. The windscreen may be painted in a realistic transparent colour.
1.18 Side windows and rear window may be opened.
1.19. No wheels, tyres or rims of the car may extend outside the bodyshell, as viewed from above.
1.20 Cut-outs in the body that were not in the original full scale version will be allowed for the following:
l - The cylinder head and air filter must follow their contour and have a maximum of 10 mm/0.4 in. clearance on all sides
2 - The aerial hole will be no larger than 10-mm/0.4 in. in diameter
3 - The radio switch hole will be no larger than 13-mm/0.52 in. in diameter
4 - Cut-out for the fuel filler cap will follow the contour of the above piece with a maximum of 10 mm/ 0.4 in. in gap between the body and the filler cap as viewed from above.
5 - The hole for the exhaust pipe must follow the contour of the above piece with a maximum of 10-mm/0.4 in. in gap between the body and the exhaust outlet
6 - The slot for the rollover bar should be no more than 10 mm/0.4 in. in width. The bar should not protrude more than 38 mm/1.5 in. above the body and not exceed a total height of 190-mm/7.5 in. from the ground
1.21 A spoiler/wing, which conforms to AARCMCC regulations, may be fitted.
1.22 Spoiler/wing sizes for sports cars/prototypes:
Maximum width 267 mm/10.5 in.
Maximum length 77 mm/3.1 in.
Maximum height 191 mm/7.6 in.
Maximum angle 45 degrees.
1.23 Fuel:
Fuel may only contain Methanol, oil/lubricant and nitro methane (with a maximum of 25% measured in volume). To implement this rule, Organisers will provide the appropriate Serpent/EFRA fuel check system at Technical Inspection. Random fuel tests will be made during the entire championship. Samples and counter samples will be collected for analysis and any competitor found to be using any substance other than those mentioned above will be disqualified and any race result obtained will be null and void. Further punishment to be determined by AARCMCC, such as a ban from future racing.
1.24 The minimum weight limit of the cars is 2500 grams/5.51 pounds. The weight limit will be checked with the cars being ready to race but with empty tank and without timing transponders. The weight will be checked by a set of digital electronic scales and can be done at any time during the meeting, i.e. before the start of a heat, sub-final or final or after the end of either. An approved test weight must be provided for checking calibration of the digital electronic scales.
1.25 The car shall be measured for the width by placing it on a baseboard equipped with two side rails of 25.4 mm/1 in. in height spaced 267 mm/10.5 in. apart, constructed in such a way that the car can roll freely between them. Baseboard and rails must be constructed of high quality material, suitably stiffened to prevent distortion. The car must roll freely between the rails with any steerable wheel set in the straight-ahead position, irrespective of the compression or extension of the suspension.
The car shall be measured for length and height in a similarly constructed box of internal dimensions 637 x 267 mm/25 x 10.5 in. which includes provision for checking the maximum height. Measurement of the wheel base may be made by simple measurement of axle centre distance but the Race Director should be prepared to make more exact checks in case of doubt or protests. It is suggested that the wheels are removed and the wheel spindles firmly placed on V-blocks whilst accurate measurements are made.
It is the responsibility of the driver to ensure that his car complies with the regulations at all times it is on the track and the organiser may check any car, at any time during the championship, for compliance with the regulations. On checking immediately after a race, if a car is found to be under the minimum weight or has incorrect dimensions, positive proof of race damage may prevent disqualification.
1.26 The maximum carburettor size will be 9.00 mm/0.35 in.
1.27 Technical restrictions:
Not allowed: 4 wheel brakes (no independently controlled braking on the front wheels is allowed)
Liquid cooled engines
Hydraulic systems
More than 2 servos
No more than 3-speed transmissions.
1.28 Driver Aids - The use of traction control devices, active suspension devices and any steering control aided by gyroscopes/’G’-force sensors is strictly forbidden. Sensors are only allowed for the purpose of passive data recording and not for adjusting the performance of the car whilst in motion. It is the object of this rule to ensure that the AARCMCC sanctioned events be a test of driver skill.
SECTION TWO 1/10TH I.C 2.5cc - TECHNICAL SPECIFICATIONS
2. Generally the specifications allow cars with two or four wheel drive, mechanically operated brakes must be fitted acting on the rear wheels only, two speed transmission, 2.5cu. cm (0.152 cu.in) engine, and a minimum weight of 1900 grams/4.1887 lbs.
An IFMAR approved fuel tester NITROMAX 16, will be available to race organisers to verify the conformity of fuel to the rules.
2.1 ENGINE RULES
The engines shall be air cooled, with front rotary shaft valve, two stroke induction type and may have a maximum of four (4) gas ports including the exhaust port, no additional holes in the liner and no holes in the piston allowed. The top outer diameter of the piston must be in a flat single plane and at ninety (90) degrees to the side of the piston. The highest part of the piston will be the outer diameter. The crankshaft hole shall have a maximum diameter of 7.00 mm/. 272 in. on its end. No form of forced induction is allowed or any form of variable port timing. Only glow plug ignition using standard 1/4-32 UNEF glow plugs is permitted.
2.1.1 During scrutineering, engines which drivers intend to use at the event must be submitted to Technical Inspection to be checked and sealed. If, for any reason, a driver wishes to use another engine during the event which has not been previously scrutineered, it must be submitted to the Technical Inspection Officer to be checked and sealed before it can be officially used in the event.
5.1.2 Only engines which have been inspected, found to comply to the rules and sealed by the Technical Inspection Officer will be allowed to be used. The decision of AARCMCC on whether an engine complies with AARCMCC rules is always final.
2.2 ENGINE DIMENSIONS
Capacity 2.5 cc/. 152 cu.in.
Stroke minimum 14.0 mm/. 551 in.
Exhaust Port height 4.5 mm/. 177 in.
Maximum diameter of the crankshaft hole on its end 7.0 mm/. 275 in.
Carburettor maximum - throat diameter 6.0 mm/. 236 in.
2.2.1. DEFINITIONS: The exhaust port height is considered to be the distance from the crown of the piston to the uppermost point of the exhaust port measured with the piston at the bottom dead centre of its stroke. The crankshaft hole shall be a straight parallel hole with a maximum diameter of 7.0 mm/. 275 in.on its end. The hole can be finished with a continuous unbroken chamfer with a maximum width of 0.5 mm/. 019 in. if this is required for manufacturing purposes at the crank web end. The carburettor bore diameter restriction is to be measured at the smallest section of the carburettor bore above the point where the fuel enters the carburettor throat.
2.3 FUEL TANK
The fuel tank including filter and fuel pipes up to the carburettor may hold a maximum of 75 cc/2.54 fl.ozs. No loose fuel tank inserts allowed.
5.4 MUFFLERS
5.4.1 A muffler of approved double chamber design must be fitted having the following dimensions:
Tail pipe maximum internal diameter * 5.2 mm/. 205 in.
Tail pipe minimum length 15.0 mm/. 59 in.
The tail pipe must be oriented on or below the horizontal.
* This dimension includes a tolerance to account for manufacturing variations in commercially available tubing.
2.5 OVERALL DIMENSIONS
Minimum Maximum
Wheel base 260 mm/10.24 in. 280 mm/11.02 in.
Track width 250 mm/9.84 in.
Overall length 490 mm/19.29 in.
2.5.1 The car shall be measured for the width by placing it on a baseboard equipped with two side rails of 25.4 mm/1 in. in height spaced 250 mm/9.84 in. apart, constructed in such a way that the car can roll freely between them. Baseboard and rails must be constructed of high quality material, suitably stiffened to prevent distortion. The car must roll freely between the rails with any steerable wheel set in the straight-ahead position, irrespective of the compression or extension of the suspension.
2.5.2 The car shall be measured for length and height in a similarly constructed box of internal dimensions 490x250 mm/19.29x9.84 in. Measurement of the wheel base may be made by simple measurement of axle centre distance but the Race Director should be prepared to make more exact checks in case of doubt or protests. It is suggested that the wheels are removed and the wheel spindles firmly placed on V-blocks whilst accurate measurements are made.
2.5.3 It is the responsibility of the driver to ensure that his car complies with the regulations at all times it is on the track and the organiser may check any car, at any time during the championship, for compliance with the regulations. On checking immediately after a race, if a car is found to be under the minimum weight or has incorrect dimensions, positive proof of race damage may prevent disqualification.
2.6 WEIGHT
2.6.1 The weight limit will be checked with the cars ready to race, but with empty fuel tanks and without transponder.
2.6.2 Minimum weight 1900 grams/4.1887 lbs.
2.6.3 The weight will be checked by a set of digital electronic scales and can be done at any time during the meeting, i.e. before the start of a heat, sub-final or final or after the end of either. An approved test weight must be provided for checking calibration of the digital electronic scales.
2.7 FUEL
2.7.1 Fuel will only contain Methanol (Methyl Alcohol), lubricating oil and a maximum of 16% Nitro methane measured in volume. The specific gravity of the mixture may not be heavier than 0.87. An IFMAR approved fuel tester, e.g. NITROMAX 16, will be available to verify fuel’s conformity to the rules at Technical Inspection.
2.7.2 Random fuel tests will be made during the entire Championship. Samples and counter samples will be collected for analysis and any competitor found to be using any substance other than those mentioned above will be disqualified and any race result obtained will be null and void. Further punishment to be determined by AARCMCC, such as a ban from future racing.
2.7.3 Only one (1) fuel bottle will be allowed in the pitlane for refuelling a car.
2.8 TYRES
Tyres must be black, except for side wall detailing.
Tyre diameter Front 75 mm maximum/2.95 in.
Tyre diameter Rear 80 mm maximum/3.15 in.
Tyre width Front 30 mm maximum/1.18 in.
Tyre width Rear 51 mm maximum/2.00 in.
No tyre additives or cleaners allowed.
2.9 RIMS
Maximum diameter for Front and Rear rims is 51 mm/2.00 in.
2.10 BODIES AND WINGS
2.10.1 For Sanctioned Events Clubs have the choice of either Group C Bodies or 4 Door Body shells from the following full-size classes will be allowed (Clubs to advise at time of distribution of entry forms):
FIA 2-litre Championship
German Touring Car Championship
Australian Touring Car Championship
North American 2-litre Super Touring Car Championship
2.10.2 Only bodies that are approved and listed by IFMAR will be allowed. The body must be made from a flexible material, painted properly, and must be one piece and used in the standard form, (bodyshell + wing), with no modifications or additions allowed (i.e. separate front spoiler, for example).
2.10.3 All bodies must have the front and rear sides cut out for the wheels if the original was so designed.
2.10.4 No wheels, tyres or rims of the car may extend outside the bodyshell, as viewed from above.
One (1) cooling hole may be cut in the front windscreen with a maximum dimension of 50% of the front windscreen.
2.10.5 Only the front side windows and the rear window may be removed, partly or totally; other windows must remain clear.
2.10.6 All parts of the vehicle must be covered, except:
Aerial (max. 10 mm/.39 in.)
Outlet pipe of muffler (reasonable clearance)
Only if these parts are extending the body.
In addition to this the following holes are allowed:
for muffler outlet
for refuelling (max. 30 mm/1.18 in.)
for glow plug (20 mm/.787 in.)
fuel mixture valve (max. 10 mm/.393 in.)
2.10.7 Rear of the body may not be cut away higher than 45 mm/1.77 in. measured with a 10 mm/.393 in. spacer under the chassis plate, and rear side-light details must remain. Side profile must remain unaltered. Rear Bumper line must remain.
2.10.8 Roll-bars (Roll-over Bars) must be kept under the body.
2.10.9 Wings are allowed only if fitted in the original car, and must be in the original position and may not project above the height of the roof line. Side dams may be fitted but must be a reasonable representation of those fitted to the original car and may not be wider than 55 mm/2.16 in. and higher than 25 mm/.98 in. and fit in a rectangle of these measurements and may not project above the height of the roof line.
Wing width 230 mm/9.05 in. Maximum
Wing chord 55 mm/2.17 in. Maximum
(A 20 mm/.787 in. extension to the wing in the form of a tab/gurney flap is allowed, but must be clear and unpainted and still may not project above the height of the roof line).
A level meter should be used to verify that wings and the allowed 20mm/.787 in. extension do not project above the height of the roof line with a 10mm/.393 in. spacer under the chassis plate on level.
2.10.10 Cars must be equipped with a flexible "plastic" bumper to minimize injuries. The bumper may not protrude outside the body.
2.10.11 All cars will be equipped with brakes and a clutch in such a manner that the car may be held stationary with the engine running.
2.10.12 The aerial must be made from a flexible material in such a manner that it will bend completely under the weight of an inverted car.
2.11 TECHNICAL RESTRICTIONS
2.11.1 Not allowed:
2 Door Body Shells
4 wheel brakes.
Liquid cooled engines.
Hydraulic systems.
More than two (2) servos.
No more than 2-speed transmissions.
2.12 TELEMETRY & DRIVERS’ AIDS
2.12.1 It is not allowed to use any electronic devices with the exception of:
Two radio channels of the receiver which will be used to operate steering, throttle and brakes.
A passive data recording or information system to record functions of the car can only be used up to the end of controlled practice.
2.12.2 The use of traction control devices, active suspension devices and any steering control aided by gyroscopes/’G’-force sensors is strictly forbidden. Sensors are only allowed for the purpose of passive data recording and not for adjusting the performance of the car whilst in motion. It is the object of this rule to ensure that the AARCMCC Sanctioned Events be a test of driver skill.
1/10TH I.C. 200mm CLASS
1. TECHNICAL SPECIFICATIONS
1.1 The class/es run will be the “200mm PRO-TOURING CAR”.
Only one brake, working on the central power transmission, is allowed. No second or individual brake system(s) for front and/or rear axles or single wheels is allowed.
1.2 Maximum 2 speed Gearbox Allowed.
1.3 All cars must have a de-clutching device and have an operating brake capable of stopping the car and holding the car motionless with the engine running.
1.4 The use of .12 engines only will be permitted. They shall be air-cooled, with front rotary valve, two-stroke induction. The engines may have a maximum of four (4) ports, including the exhaust port. No form of forced induction is allowed or any form of variable port timing. Only glow plug ignition is allowed. No holes in the piston and no additional holes in the liner. The carburettor size is to be 5.50mm. The exhaust port height is to be 4.30mm max. No Turbo style glow plugs only ¼ UNF plug types.
1.5 Engine capacity is to be maximum .12 (2.11cc) only.
1.6 Standard pull start is optional.
1.7 Engine internal modifications are allowed as long as they are within the parameters of Rules 1.4 and 1.5.
1.8 A muffler of approved double chamber design, including silencer chamber must be fitted having the following dimensions:
i) Tail pipe maximum internal diameter* 5.20mm.
ii) Tail pipe minimum length 10.00mm.
iii) The tail pipe must be oriented on or below the horizontal.
1.9 Minimum weight without fuel, including transponder: 1700.00 grams.
1.10 Fuel tank capacity to be 75.00cc including all fuel tubing, filters, etc. No loose inserts allowed inside tank.
1.11 Touring car bodies shall be accurate 1/10th scale representations of the following full-size 4 door touring cars which have been homologated by the F.I.A. and which have been approved: -
North American 2-litre Super Touring Car Championship.
1.12 The front bumper must follow the body contour and must be constructed so as to minimise injury that may result from being hit by a car. The bumper must be made from foam rubber or a flexible plastic material.
1.13 The body must be made from a flexible material and be painted properly. All windows must remain clear and not be painted over or be semi-transparent.
1.14 Bodies are not to be cut above the lower bumper line at the front or the back nor above the bottom line of the doors. Details of all front and rear lights, grills, air intakes and windows must be clearly contrasted from the surrounding paintwork.
1.15 Only the following AIR HOLES and sizes are permitted in the bodyshells:
i) One (1) cooling hole may be cut in the front windscreen with a maximum dimension in any direction of 50% of the front windscreen.
ii) 15.00mm maximum diameter hole in the roof for glow plug access.
iii) Both front side windows and the rear window can be removed for ventilation, except for the side rear windows, which must remain intact. (No part of the windows can be bent or folded to form an aerodynamic aid.
iv) Re-fuelling hole maximum 50.00mm diameter.
v) Small holes can be made for the exhaust pipe, transponder and radio antenna.
vi) No other holes are permitted.
1.16 Roll-bars (roll-over bars) must be kept under the body.
1.17 No parts of the car, except the muffler outlet may protrude outside of the bodyshell when viewed from above.
1.18 Under body/chassis aerodynamic aids of any nature are not allowed.
1.19
General Dimensions Minimum (mm) Maximum (mm)
Wheelbase 230 270
Width (without body) 170 200
Width (with body) 175 205
Length (including body and wing) 360 460
Height (to top of roof) 110 175
Wing width inclusive 125 195
Wing Chord 40 50
Wing endplate 35.00 x 50 equal size
Wing overhang (at rear) 10
Wheel diameter (excluding tyre bead) 46 50
Wheel Width including Bead 24 26
Tyre width (across sidewalls) 24 26
1.20 One wing and one spoiler may be mounted to any car (if the original full-size car had more, it is allowed to do the same). Wing and spoiler must be made from a flexible material and be painted. Wing and spoiler must not be fixed to body with piano wire. Basically, they must be mounted to body directly. Wing and spoiler may not protrude outside the maximum height and width of the body (including the side dams). Rear wings must be mounted in the same place as was intended by the body manufacturer. The overhang must not exceed 10.00mm at the furthest point, to be measured from boot lid.
The height of the wing may be adjusted but the wing, including endplates must not extend higher than the roofline. Wings (excluding endplates) are to be of single moulded construction (no flat-packs/bend your own). Gurney strip (if allowed) may not exceed the width of the wing and have an edge not more than 5.00mm high. Total cord of wing, plus the strip is 55.00mm.
2 Tyres
2.19 Pro-Touring: Foam and/or Rubber tyres may be used. Any materials used in, or on, the tyres must not damage the racing surface. Treatment of the tyres with additives is prohibited.
2.20 Fuel will only contain methanol (methyl alcohol), lubricating oil and a maximum of 16% nitro methane in volume. The specific gravity of the mixture may not be heavier than 0.87. An IFMAR approved fuel tester, e.g. Nitromax 16 will be available to verify fuel’s conformity to the rules at Technical Inspection. Any fuel adjudged to be dangerous by the Organiser or Race Director may not be allowed.
2.21 The aerial support must be flexible. Carbon, GRP, steel, etc. are not allowed.
2.22 Only two (2) servos are allowed. Frequency must be legal as specified by Race Director. Drivers must have more than one (1) frequency available. Under no circumstances shall a transmitter be taken onto the track.
2.23 The use of electronic gyroscopes is not allowed
2.24 All measurements referred to in these rules are maximum or minimum values. Illegal measurements will be to ISO norm. All figures in the rules should be two (2) decimal digits.
FINIS
Section 4 Format Rules I.C Racing
4.0 See General Rules for basic requirements regarding Heats, Finals and meeting procedures.
4.1 FINALS
All finals will be run using the Xmas Tree system. The exception is when there are less than 16 entries the A, B, C final system may be run.
All sub-finals and final consist of eight (8) or ten (10) drivers. The Main final always has ten drivers.
"Christmas Tree" System for 150 entries
1/1024 final even numbers 150 - 132 odd numbers 149 - 131 *
1/512 final even numbers 130 - 118 odd numbers 129 - 117 *
1/256 final even numbers 116 - 106 odd numbers 115 - 103 *
1/128 final even numbers 102 - 90 odd numbers 101 - 89 *
1/64 final even numbers 88 - 76 odd numbers 87 - 75 *
1/32 final even numbers 74 - 62 odd numbers 73 - 61 *
1/l6 final even numbers 60 - 48 odd numbers 59 - 47 *
1/8 final even numbers 46 - 34 odd numbers 45 - 33 *
1/4 final even numbers 32 - 20 odd numbers 31 - 19 *
1/2 final even numbers 18 - 6 odd numbers 17 - 5 **
* First three go forward. Duration 15 or 20 minutes.
** First two go to final; then the next two fastest from either semi-final go to final. Duration 20minutes and 30 minutes for a National
CHAMPIONSHIP FINAL TO BE RUN OVER THIRTY (30) MINUTES FOR STATE TITLES AND FORTY FIVE MINUTES FOR NATIONAL TITLES.
4.2 RAIN SITUATION
The Race Director will stop the racing if it rains. If there are delays due to weather, re-arrangements will be made as follows:
QUALIFYING HEATS
1 - In case of the interruption of a heat, the entire heat will be re-run.
2 - In the event of rain, the track must return to 100% dry conditions before racing can re-commence. The 100% dry conditions will be determined by a majority decision of the International Jury.
3 - If a round of heats is started, it must be completed under the same conditions. If a round is halted due to rain or unforeseen circumstances and cannot be completed, this round will not be counted until the remaining heats in the round can be completed.
4 - If weather and time permit and there is no time restriction on track use, every endeavour should be made by the Race Director to run as many of the maximum six (6) rounds of heats as possible.
5 - A minimum of two (2) of the total of six (6) rounds must be completed.
CHRISTMAS TREE FINALS
1 - The lower finals up to the 1/4 final will not be interrupted due to a wet track or rain.
2 - In the event of rain during the 1/4 final, if 50% of the race has been run before the rain, the race is declared. If rain falls before 50% of the race has been run, the results will be kept from the moment of stopping which will be the previous lap when the leading car crosses the finishing line. The new start will be given for the time which remains to complete the final. The two results will be added to give the final and definite placing’s. If the second start cannot be given for any reason, the results from the first part will be used as the final and definite placing’s.
3 - In the semi-finals, if 75% of the race has been run before rain commences, the race is declared. If rain falls in the first 25% of the race, a total re-run will take place. If rain falls between the 25% and 75% mark, the total of the two (2) combined legs will be added together.
4 - In the event of a semi-final being interrupted in this way, the top three (3) from each semi-final will advance to the final.
5 - In the event of rain falling before the 25% mark where a complete re-start is required, drivers will be allowed to undertake maintenance on their cars.
6 - MAIN FINAL - If 75% of the main final has been run before rain commences, the race is declared. In the event of the main final being interrupted by rain where the two results will be added together (i.e. after the 25% mark), drivers may make repairs, re-fuel and change tyres before the re-commencement of the main final.
4.3.1 RACE PACKAGE
During registration, every driver will be given an envelope which includes: A detailed schedule including starting times of each heat, 3 sets of numbers for the car (each car decal to measure not less than 57.15 mm/2.25 in. high x 38.10 mm/1.5 in. wide with a stroke of 9.52 mm/.375 in., 3 sets of numbers for the wing, l number for the transmitter, l badge for the driver, l badge for the mechanic/s will be issued. Also included in the package there must be a sketch showing the correct positioning of the car numbers on the bodyshell.
4.3.2 NUMBERING OF CARS
Cars will be numbered 1 to 10 in each heat.
Each car must have 3 numbers: - one on the front, one on the right side, and one on the left side.
These numbers will change during the qualifying heats (after re-seeding).
The organiser will provide other numbers for altered heats and for sub-finals and final.
Number decals may not be trimmed to eliminate the background.
4.3.3 NUMBERING OF THE BODY/WING
The competitor's number is put on the body/wing. It is the same for the entire competition.
The first or the first two digits indicate the heat number.
The last digit is the car number (i.e. number 12 means heat 1, car 2).
The numbers provided by the organiser must be attached to the right side of the body/wing, the other side being reserved for the competitor's national flag. Every competitor must have his national flag on the left side of the body/wing of his car (when looking from the rear).
4.3.4 NUMBERING OF TRANSMITTERS
Every transmitter will have the competitor's number on it. (The same number as on the wing.)
4.4 BADGES
4.4.1 DRIVERS, MECHANICS AND TEAM MANAGERS
Two badges will be given to each competitor, blue for the driver, yellow for the mechanic. The designated
4.4.2 ACCESS TO PITS AND TRACK
Orange badges/team managers - pits, staging area, special viewing area
Blue badges/drivers - drivers' stand, pits, staging area
Yellow badges/mechanics - pits, staging area
Green badges/Press - pits, staging area, special viewing area
Red badges/race officials - all areas
Grey badges/AARCMCC officials - all areas
4.5 PITS
In the event of a large number of entries places should be allocated for the duration of the event.
Places are grouped by State and marked by sign plates. Pits are covered. Every competitor will have a 60 x 120 cm (2 x 4 feet) table space.
Pits are equipped with 220 V/50 AC. Limited quantity of transformers will be available.
12 V DC (limited) in starting area
4.6 TRANSMITTERS
4.6.1 TRANSMITTER IMPOUND
All transmitters must be placed in impound upon arrival at the track.
Transmitters will be furnished to each competitor after completion of technical inspection and prior to their heat. All transmitters must be returned to impound following their heat. Transmitters in the pit area, or areas other than the drivers' stand and impound, during official competition hours, will cause disqualification.
4.6.2 TRANSMITTER INSPECTION
All transmitters must be tested and inspected prior to their use. A spectrum analyser will be used for radio inspection. All transmitters passing inspection will be identified and only these transmitters, thus identified, may be used in the event.
4.7 LAP COUNTING AND TIMING
Automatic lap counting, with cumulative and split lap times, will be in place for each car. Competitors are required to install a small transponder into their cars according to the organiser's instructions. An audio/video tape recording will be made.
Significant stops (refuelling, tyre changes, crashes, etc.) will be noted with times of stop and restart. This record might not include every incident, however, its intent is to verify incidents, whenever possible.
AMB lap counting system or AARCMCC approved equivalent must be used in duplicate.
A suitable working computer with proper race proven programmes must be provided to sort lap times, print results from heats and sort final positions from each round of heats within l5 minutes of the completion of the round of heats.
Chronometers must give time to 1/100th of a second, in all cases, the hundreds will be utilised.
In the case of equal results, the following best heat will separate the competitors.
If both the primary and support lap counting systems fail during a qualifying heat or final, the heat or final will be re-run as soon as is practicable. Under no circumstances will any lap score or time, other than those from the official time keeping equipment, be accepted for any purpose to do with the running of an AARCMCC race.
4.8 DISPLAYS AND DISTRIBUTION OF THE RESULTS
The display of the positions in a specific heat or final will be done in the pits.
At the end of each heat (every l5 minutes) or of the finals, a copy of each competitor's lap sheet will be available for checking and information. Copies of the time-lap sheets of all cars of the heat or the final will be displayed with the result.
At the end of each round, after the l5th heat, results of the general classification will be available.
5. TRACK SPECIFICATIONS
5.1 SURFACE
Track surface should be unsealed asphalt or coarse finished concrete with smooth joints, if any.
5.2 LENGTH
The minimum length of the track is 250 metres/820 feet. Advised is 250 - 300 metres/820 - 984 feet.
5.3 WIDTH
The minimum width of the track is 4.0 metres between marking lines. The maximum width is 6.5 metres/ 2l feet.
The marking lines must be 8-10 centimetres/3-4 inches wide.
5.4 PODIUM
Maximum distance from the middle of the drivers' podium to the furthest point of the track is 60 metres/l97 feet.
Minimum height of the drivers' podium is 2.5 metres/8 feet from track level and the podium is at least l0 metres/33 feet long.
5.5 VISION
No obstacles may interrupt the vision from the drivers' podium to all parts of the track.
5.6 MARKING
A broken line may be painted in the middle of the straight to increase the vision.
5.7 PITS
The refuelling and pit area should be clearly distinct and separated from the main track and as close as possible to the drivers' podium.
Exit from and entrance to the main track is advised to be on a slow section of the track.
5.8 DESIGN
Track design must include both right and left turns and must have a straight of minimum 60 metres/l64 feet.
5.9 OUTSIDE BARRIERS
Outside barriers must provide positive means of stopping a car when missing a corner or out of driver's control. The consideration at selection of the outside barriers shall be the protection of the spectators and not the cars, although, if both can be obtained, it is ideal. The outside barriers must be at least 40 centimetres/l6 inches away from the marking lines of the track.
5.10 INSIDE BARRIERS
Inside barriers must avoid shortcutting of corners or cars getting on other parts of the track.
Inside barriers must be positioned and dimensioned to avoid cars flying over the outside barriers into the public.
Inside barriers must be smooth and must be 20 centimetres/8 inches away from the marking lines on the track
5.11 DOTS
No dots will be used on high-speed sections.
5.12 SURROUNDINGS
The inner and outer surroundings of the track must have grass or other suitable materials, such as concrete. The object of these surroundings is to slow down the car that leaves the track. The car must be able to leave the infield or outfield on its own to minimise marshall assistance.
5.13 MARSHALL POSTS
Marshall posts must be available for every 30-meters/100 feet of the track length. They may not obstruct the vision of the drivers. The posts must be numbered. When a post is located on a dangerous part of the track (i.e. the straight or a fast corner), this post must then provide protection for the marshall (wall, tyres, gate, etc.).
5.14 STARTING LINE
A starting line must be painted across the track, preferably in front of the time keeping. The vision of the starting line may not be obstructed by the mechanics holding the cars or by the starter and starting equipment. The starting line must be located more than 10 metres/33 feet away from the first corner. Ten numbered boxes of 70-100 centimetres/27-40 inches long are painted with the starting line forming the front of all the boxes. The hold line for the mechanics is located 1 metre/3.3 feet behind the boxes.
5.15 LE MANS START
For the "Le Mans" type starts, 10 numbered boxes are located on the side of the track at an angle of 20-45 degrees with the track, at a minimum of 2 metres/7 feet and maximum 4 metres/14 feet apart. The boxes must measure 70-100 centimetres/27-40 inches long and 30-40 centimetres/12-16 inches wide.
6. RACE PROCEDURES
6.1 POSITIONING
Mechanic must be positioned under his driver's position. During finals, positions will be selected by drivers in order of qualifying position, i.e. No. l qualifier has first choice, No. 2 qualifier has second choice, etc. During qualifying heats only one (1) mechanic is allowed per car. During finals two (2) mechanics are allowed per car.
The use of all electronic communication devices between drivers and mechanics is banned during heats and finals.
6.2 GENERAL STARTING PROCEDURE
6.2.1 HEATS - There must be a 5-minute gap between the end of one heat and the start of the next. Also a minimum of 3 minutes must be allowed between the issuance of the transmitters and the start of the heat.
6.2.2 An audible warning will be given in English language at 1 minute and at 30 seconds
6.2.3 A staggered start timing system will be used during qualifying. The cars will leave the starting boxes after the starting signal in the following order:
ROUND 1: 1 2 3 4 5 6 7 8 9 10
ROUND 2: 3 4 5 6 7 8 9 10 1 2
ROUND 3: 5 6 7 8 9 10 1 2 3 4
ROUND 4: 7 8 9 10 1 2 3 4 5 6
ROUND 5: 9 10 1 2 3 4 5 6 7 8
ROUND 6: 10 9 8 7 6 5 4 3 2 1
Each car's individual official time will start when the car passes the timing system for the first time. When the first car completes the first lap, all official timing not yet activated will be started.
SUB-FINALS AND FINALS
6.2.4 An audible warning will be given in English language at 1 minute and at 30 seconds.
6.2.5 From 30 seconds until 3 seconds the cars may be placed in the starting boxes. If a car is not in the starting box at the 3-second mark, it must start from the pitlane after all cars have started officially.
6.2.6 From 10 seconds until 3 seconds, time is counted down in English language, second by second.
6.2.7 At 5 seconds, the starter will lower the starting flag and at 3 seconds. the flag will be down, touching the ground. At this time, cars must be released by the mechanics who will all step back behind the hold line. The cars must remain in the boxes, no part of the car touching the starting line.
6.2.8 From 3 seconds, the counting stops and the start signal will be given by the starter between 0 and 5 seconds. If the grid is not to the satisfaction of the starter, he may command a re-start, beginning the count down from 30 seconds.
6.2.9 The official starting signal will be audible by means of a horn operated by the starter. This signal will also start the timing systems.
6.2.10 Early starts - ALL FINALS ONLY.
Early start (i.e. any car touching the starting line) will be penalised with the loss of one lap. This penalty is issued by the starting official or the time-keeping official and has to be announced immediately after the start. The penalty will be marked on the result sheet.
6.2.11 Under no circumstances will the race be stopped due to a jumped start.
6.2.12 Only the Race Director may interrupt the race and order a restart in the event that he considers the starting procedures or the start were not carried out correctly.
6.2.13 DELAYED START - As long as the starter has not called the cars to the starting line, every participant of the semi- finals and the final may request a delay of 10 minutes for repairs on his car. The delay will be granted only once for each semi-final and final. The track shall be closed to all cars during the delay period
6.3 MARSHALLING
6.3.1 Marshalling shall be provided by the racers. The Race Organisers will provide 2 designated fill-in marshals to cover unforeseen eventualities. After each heat the participants in that heat will place their cars into impound and assume assigned marshalling positions for the following heat. No other person is allowed on the track (except officials) while the race is in progress.
6.3.2 When there is a break, staggering of heats or a change in the running order of heats, any driver that is responsible for marshalling will be properly notified either in person or through his States Representative and/or Race Director.
6.3.3 Any person not marshalling or providing a qualified marshal shall lose their fastest qualifying time.
6.4 TECHNICAL INSPECTION
Only vehicles which conform to all regulations will be accepted for racing. The cars will be examined and, if the car conforms to the rules, the chassis and the fuel tank will be marked. At any time, the Race Director may ask the competitors to present their cars to the Technical Inspector. Random inspection will occur on the start line for numbers, tyres, wings and chassis.
No race will be delayed because of non-compliance by a competitor. At the completion of each heat all cars in that heat, whether they finished or not, must be presented for technical inspection. Cars which are not presented for technical inspection at the end of a heat will be disqualified from that heat. Any race damage will be taken into account. At the end of finals, all cars will be impounded and may be inspected for engine size, fuel tank capacity, etc.
Any infringement concerning engine, fuel tank and weight will cause disqualification from a driver's best qualifying heat or a final. A second infringement concerning any one of engine, fuel tank or weight, will cause total and immediate disqualification from the entire event. Any infringement, other than those concerning engine, fuel tank and weight, will cause disqualification from that heat or final.
All cars must be fitted with a clutch, a braking system and a homologated exhaust.
The engine and fuel tank may be checked at any time.
The volume of the fuel tank will include all fuel piping and filters up to the carburettor.
Following method of measurement will be used:
- pinch off pressure lines
- fill the fuel tank completely
- remove fuel pipe from the carburettor inlet
- connect a calibrated syringe to the fuel line which has been disconnected from the carburettor and pull all the fuel into the syringe. The amount of fuel removed by the syringe will be considered as the total content of the fuel system.
* Only one car per driver will be accepted.
* The chassis plate and the fuel tank of each car will be marked with the competitor's number.
* Only one chassis may be used for all qualifying heats and finals. The only exception to this rule will be in the case of a broken or bent chassis which may be changed with the Race Director's approval. The new chassis must be presented to technical inspection for marking before re-building the car.
6.5 FREQUENCIES
In the case of two drivers using the same frequency and qualifying for the same final, the higher placed driver may keep his frequency and the lower placed driver must change. The time allowed for frequency change will be 10 minutes. The lower placed driver who cannot or will not change his frequency may not take part in the final for which he qualified.
If a driver must change his frequency before the start of a semi-final or a final, due to an organiser's error, he will be allowed 10 minutes. If a driver finds his radio defective or has made an error in the selection of his frequency at the start of a final, the race will not be delayed.
For the entire duration of the event, the frequencies in use by all drivers will be known only by the Race Director and each individual driver.
All frequency changes must be authorised by the Race Director before the change is made.
The organiser shall not display any driver's transmitter frequency on any heat sheets, result sheet or race schedule to preserve the security of the frequency control systems. Each driver in the main final shall be permitted to change his frequency before the start of the race. Only the Race Director is permitted to know the frequency used by the main finalists.
6.6 CAR NUMBERS AND LAP COUNTING TRANSPONDERS
Only the numbers supplied by the organiser will be used on the cars.
Each participant is responsible for attaching the lap counting transponder to his car. During qualifying, any car starting without a lap counting transponder will not be counted. If a lap counting transponder fails or falls off during the heats, the vehicle will be timed and counted manually, if possible. In this case, the Race Director will verify the results and his decision will be final.
During the final, any car without a lap counting transponder will be counted manually by a manual back-up system. Under no circumstances will a heat or a final be re-run due to a car not having a lap counting transponder or failure of the same. This also applies to a car not having the correct numbers and placement of these numbers.
6.7 FLAGS
Start - green flag or national flag
Finish - chequered flag for final only
Blue - The car which is blue flagged must allow the car behind him to pass.
Yellow - Danger on the track - slow down
Black & white - Official warning to the car which is flagged (diagonal)
Black - The car in question must stop immediately in the pits
Green - Track open
Red - Track closed. All cars must stop immediately.
The black and white diagonal and the blue flags are recommended but are not compulsory.
All flags are under the direction of the Race Director who can delegate and authorise their use.
6.7.1 USE OF THE BLACK FLAG
- Drivers who impede the progress of other participants
- Unsportsmanlike racing
- Participants driving in a manner deemed to be dangerous by the Race Director
- Cars judged by the Race Director to be in an undriveable or dangerous condition. These cars, after the repairs have been carried out, may be allowed to resume.
- Cars which lose their bodies or silencers must immediately stop and carry out the necessary repairs after which they may restart
- Cars which have been black-flagged may re-enter only with permission from a Race Official.
6.8 RACING REGULATIONS
6.8.1 PROTEST AGAINST A COMPETITOR OR THE ORGANISER
Protest must be entered by the driver/Team Manager/State delegate, in writing, within 10 minutes after the display of the result or after the incident it concerns, with a deposit of $50 AUS. The time of display of the result will be written on the result sheet. The deposit is forfeited if the protest is not upheld and the deposit is returned if protest is justified. Protests may be handed to the Race Director or an AARCMCC Official. Protests are processed by the Race Director and, if necessary, by the Jury. Appeal to AARCMCC may be made. AARCMCC is not obliged to handle such appeal. Deposit returned if protest is upheld.
6.8.2 REQUESTS FOR LAP COUNTING CHECKING
Requests do not need to be written and need no deposit. The driver/Team Manager/State delegate will show to the Race Director the time-lap sheet in question (the one given or displayed by the organiser) and will indicate where he thinks an error has been made. The Race Director will resolve the problem by checking with the second lap counter and, if necessary, with the manual record of stops. The audio/video tape may be used as a last resort, if necessary, for the final result. If the request is justified, the result will be modified immediately and the Race Director will advise the protestor, in writing, of the result. After checking, if the protestor persists with his request, he will have to present a written protest within 10 minutes, including a $50 AUS. deposit.
6.9 PENALTIES AND SANCTIONS
During finals, participants will be allowed to change the bodies of the car with the authorisation of the Race Director, providing the bodies are of the same type and painted in the same colour scheme. In the event of a different body being fitted to the car, the Race Director must give his permission before the participant re-enters the race.
Any illegal modification or change made to the car which is found during the technical inspection at the end of the race will automatically entail disqualification of the participant.
EXCEPTIONS: Tolerances allowed in technical inspection for fuel tanks
Any damage incurred during a heat or final will not entail a forced stop or disqualification of the participant except in the following cases:
- loss of a body (the spoiler does not count as part of the body)
- loss of the silencer or its ability to silence the engine
- a car that becomes dangerous or undriveable.
The car in question may re-start after the repairs have been affected.
Any car which, by the fault of another driver, is damaged or obstructed during a heat or final cannot, under any circumstances, be allowed to re-run in another heat.
All participants must strictly observe the instructions given by the Race Director, Jury and Referees. The bad sportsmanship and behaviour of any competitor, even outside the official race meeting, which could injure the image and promotion of the sport, may become the object of an official, national or international sanction.
6.10 OFFICIAL ANNOUNCEMENTS
All official announcements concerning the race must be made in the English language in the pit area, drivers' stand and mechanics' area.
6.11 OFFICIALS
6.11.1 REFEREES
Two referees (2) must be on duty at all times for National events. One (1) referee is acceptable for State title events. They must be unbiased and experienced persons with a good knowledge of the current AARCMCC rules. They must have driving experience in electric on-road racing.
The main task of the Referees is to observe the racing and in particular the good sportsmanship during the racing. They will ensure that everybody observes the correct rules.
The Referees may be called for information by the State Jury when the Race Director calls a meeting.
Referees may not be participants in the event or serve in any other official capacity.
6.11.2 REFEREES' DUTIES
At all times during the qualifying heats and finals, the Referees present will be watching and observing the racing from start to finish.
A Referee may issue warnings and instructions. A Referee may take action after an initial warning but in all cases a maximum of three warnings means automatic disqualification from the event. Any appeal against the Referee’s decision must be made to the State Jury accompanied by protest fee.
A Referee will be responsible to ensure that no race is allowed to start without all marshals in position.
6.11.3 GUIDELINES REGARDING OFFENCES
1 - Bad sportsmanship during racing, i.e. impeding progress of other participants, deliberate slowing down or walling of another car, deliberate short-cutting of corners and reckless driving in general.
2 - Unsportsmanlike behaviour of drivers, mechanics and Team Managers involved in the racing.
3 - Incorrect use of entry and exit of the pits.
4 - Repairs and refuelling outside the appointed pit area.
5 - Mechanics going onto the track during the race.
6 - Any combination of three warnings will cause disqualification.
7 - Instructions may also be given by the Referees but they do not constitute a warning. Sample of instructions follow under numbers 8 and 9.
8 - Cars that do not conform to the regulations before the start is given or during the race, (i.e. loss of bodyshell, exceeding noise rules due to loss or damage of the silencer).
9 - Cars that are in an undriveable or dangerous condition due to damage or malfunctioning of the car (one instruction).
10 - Starting procedure, i.e. writing down early starts and, if necessary, reporting to the Time Keeper. The Time Keeper and the Starter are first responsible to issue starting penalties (one lap penalty). In the event of an early start not being observed, it may be called and noted by the Referee.
11 - It is not the duty or the responsibility of the Referees to check if the cars conform to the technical rules. This is always the responsibility of the Technical Inspector.
12 -All warnings will be announced in the English language with the words: "Car number .... Warning".
All instructions will be announced in the English language with the words: "Car number .... Stop".
Each competitor must be able to recognise the above English words and statements.
6.11.4 REFEREE'S AUTHORITY
1 - The Referee issues warnings in case of infringements of any point as described under 4.11.3, and ultimately may even issue a black flag (disqualification) when there is no response to his warnings.
2 - the Referee himself announces Warnings and instructions. He will keep a record of the warnings and instructions used (Referee's notes). Three successive warnings lead to disqualification (black flag).
Instructions issued by the Referee must be observed immediately. All announcements must be made in the English language. Warnings will be posted on the result sheet.
3 - Reasons for warning or instruction will be announced in the English language at time of issue. Further explanation, if necessary, due to language difficulties, will be given to the driver or the Team Manager at the end of the race.
4 - Under no circumstances may a warning or an instruction issued by the Referees lead to the interruption of the whole race.
5 - During the event, only if all three Referees agree, they will have the authority to black flag a driver and/or a whole team, if one member of that team is positively interfering with the racing of another car in the event.
6 - Appeals to the decision of the Referee must be addressed to AARCMCC in writing. AARCMCC is not obliged to act on such a complaint.
7 - The AARCMCC Referee has the right to use his discretion to issue a penalty instead of a warning for any serious infringement of the rules.
8 - The AARCMCC Referee has the right to issue penalties for pit lane infringements. The penalties will range from time in seconds to a one (1) lap penalty.
9 - The AARCMCC Referee has the authority to instruct other race Officials to take remedial action in any situation that might compromise the well running of the race meeting. Any serious situation will be referred to the most senior AARCMCC Official present before taking any action.
6.12 TIME-KEEPING SUPERVISOR
The Time-Keeping Supervisor is responsible for recording all the individual lap times and total laps plus finishing time of all drivers during all heats and finals. He is responsible for the classification of the results and for selecting of the finals. The Race Director must verify this classification and selection.
After the finish of any heat or final, the results of the first and second time-keeping systems are compared by the Time-Keeping Supervisor and, in case of difference between the two systems, the Time-Keeping Supervisor investigates both results and makes the decision of the final result.
In case of a request for checking of the results, the Time-Keeping Supervisor, together with the Race Director, will check on the questioned result and will make the decision.
6.13 STATE JURY
6.13.1 The State Jury consists of a nominated delegate from each State represented at the event. Each State will have a total of one vote.
6.13.2 The Chairman of the Jury is the I.C or his nominated delegate. The Race Director and Chairman are members of the State Jury but do not have a vote in the decisions. The Referees may be called by the Jury for opinions and explanations as deemed necessary. All decisions are by a simple majority vote. The Jury can request evidence and/or drivers presence pertaining to matters involved.
6.14 RESPONSIBILITY OF THE STATE JURY
6.14.1 To decide in unforeseen situations.
6.14.2 To handle protests not covered by the Race Director’s responsibility.
6.14.3 To change the race procedures or cancel the race whenever this is required due to safety aspects.
6.14.4 To see that the race is run according to the official AARCMCC rules.
6.14.5 To make the decision on interrupting or cancelling a race due to rain or other weather conditions.
6.14.6 State Jury members may not have dual duties of being a race official (other than Race Director) or Referee. Jury members may be participants in the event but must allow an auxiliary representative to serve in any protests that concerns the jury member as a participant.
6.15 RACE DIRECTOR
The Race Director is responsible to follow the schedule of the event.
The Race Director ensures that various tasks under his responsibility are well done, including:
- Time-keeping
- Starts
- Marshalling
- Display of results
- Comments to the public
- Comments to the drivers
- Technical inspection
- Frequency control
The Race Director receives the protests and decides if the State Jury has to meet. He takes urgent decisions or stops a race for safety, rain or any other unforeseen situation. He is under the authority of AARCMCC.
6.16 ASSISTANT RACE DIRECTOR
The Assistant Race Director will represent the host country or organisation and will assist the Race Director in co-ordinating all race matters with host organisation officials.
David 05-26-2002 03:52 PM
There was vote a few meetings ago with regards to using 30 mm rear tyres on touring cars,which was passed by the nswrcrcc.
Did you get anymore feedback on that vote from other clubs? and will it be part of the Aarcmcc rules for future meetings/champtionship rounds?
OZDC 05-26-2002 08:09 PM
Anthony,
A question re. the following rule.
"Fuel tank capacity to be 75.00cc including all fuel tubing, filters, etc. No loose inserts allowed inside tank. "
Why no loose inserts, eg Silicon fuel tubing? It would seem to me to be the easiest and cheapest way to rectify an oversize tank which would most likely be only a few cc's due to manufacturing errors.
I understand it inherited from the other scales but i've never understood the reasoning behind it.
DC
contact 05-26-2002 09:22 PM
do you have the arcmcc electric rules as well? i was under the impression they were going to be reviewed... is that an incorrect assumption?
TrustMe 05-26-2002 09:32 PM
Tyre width voting closes 8th June 2002, results of this vote will be advertised on 9th June 2002.
Fuel tank capacity. The reason no loose inserts are allowed is that in the event of someone running an oversized fuel tank, it does not give that competitor the ability to secretly slip an insert into the fuel tank prior to end of Race Scruteneering. The simplest and easiest way to decrease the capacity of a fuel tank, is to heat the tank and depress the sides until the capacity is legal. However there has been the odd time where due to the discretion of the race director and Scrutaneer, an insert may be placed in the fuel tank, however it is up to the competotor to make sure that the Tank size is according to the rules.
When racing in a sanctioned event, the competitor should be awware of the rules, and should make sure that his car confirms with these rules prior to the first scrutaneering. When a competitor fails scrutaneering, he does so because he has not complied with the rules.
I have never been pinged at scrutaneering, simply because I make sure that my car complies, read the rules comply with them, thats how easy it is.
A.G.
VenomWorldOrder 05-26-2002 11:59 PM
regarding liverpool and asrmac rules.
i recently bought 20% nitro fuel becouse there was no 16% trinity fuel left in sydney for another 5 weeks. can i use the 20% nitro fuel for regualr moorebank meets? i noticed a few of the 200mm touring drivers use the 20% stuff, (stuart grant) can i still race or is it the case that i don't get points if i race with 20% nitro?
custom model cars had no 16% left and i'm not gonna put crappy fuel in my car.
so can i still race at morebank? i just don't get any points right??:weird:
T-shirt 05-27-2002 12:07 AM
hahahahhahhaha
i don'r think u can race with 20% fuel tom, even you race and you will not get the point.. :D
hey you can get the fuel of randal...
or one more option tom go to wing n things near brookvale they sell the trinity but more expensive than custom model car
VenomWorldOrder 05-27-2002 12:50 AM
Originally posted by T-shirt
hahahahhahhaha
hey what you talking 'bout willis, i mean rudi! :D you calling me slow??!:p
i never knew randall sold trinity fuel!!?? sh1t i payed $60 for the platinum crap! it's pritty good actually :sneaky:
maybe i can leave it in the sun and it will turn into 16% :ha:
T-shirt 05-27-2002 03:01 AM
i know but he is sell the jungle something.....
so you will run 20% fuel this sunday?????
snoopy 06-03-2002 01:54 AM
wheres the rules gone?
Wheres the "rules" gone from the AARCMCC site?
Chasing the electric 1/10 rules
Cheers
Sam
thejewishone 10-03-2005 02:57 PM
Hi There.
I was wondering if there have been any changes to whats here in the rules, and if and what are the rules regarding Staium Trucks here in Australia.
Any info would be great.
fastolfart 10-03-2005 03:37 PM
If any one needs copies of the AARCMCC electric section rules, please e mail me at Peter Ellis
Contact, no changes have happened since mid year, on road will be updated soon and sent to the affiliated clubs before the 2006 season starts.
Unfortunately, the server that the AARCMCC web site was on has thrown a rod and the person who set it up is working on recovering and rebuilding the site.
