Go Back  R/C Tech Forums > International Forums > Australian Racing
Castle Hill RC Onroad >
Like Tree19Likes
Old 05-10-2006, 02:22 AM
  #2971
The Ideas Man's Avatar
Default Driver Line up
After a big weekend at SMA, and a leave pass from the Wife, I'm looking forward to a night of Racing at the Hill.
I may even be able to convince some of the SMA members to join in the fun.
Meanwhile, here is the line up for 19 turn this Friday:
Ray Wood
Rian-S
IDM
__________________________________________________ ______________
See you this Friday . . .
IDM
The Ideas Man is offline
Old 05-10-2006, 03:24 AM
  #2972
vr01's Avatar
Originally Posted by TJ
To change the topic. I was wondering because its not a normal night this Friday weather is any body interested in running 19T. And not mixed 19T -mod but a proper 19t class.
Your thought
Hmmm, sounds interesting...
vr01 is offline
Old 05-11-2006, 03:30 AM
  #2973
TJ
TJ's Avatar
Default Trophies
Trophies for the last pointscore will be presented tomorrow night before racing starts. Results & pointscore now online.
TJ is offline
Old 05-11-2006, 07:57 PM
  #2974
TJ
TJ's Avatar
Yes it will be interesting how many turn up. Please remember we are going only to allow 19t in the 19t class. YES I know it sounds strange
TJ is offline
Old 05-16-2006, 09:24 PM
  #2975
Mad Mackem's Avatar
I think it would be a good idea to have a discussion on where we go with the Seniors Class.
Options would ssem to be:
Stick with 540 and change the body.
Change motor to 23 turn stock, 19 turn or maybe even the 540's they used as a handout at Windsor if they are available.
There may be other options, make you suggestions if you have any, or air your thoughts on the other ideas.
Please, let's not open up another discussion about the existance of the class. The class exists we are just talking about where it goes.
Mad Mackem is offline
Old 05-16-2006, 09:42 PM
  #2976
Jeff - The tamiya stockers are a good cheap alternative motor, available everywhere, even at Dick Smith stores, at under $50.
Plenty of stick without being quite as fast as a good 19t.
Besercoe is offline
Old 05-16-2006, 10:07 PM
  #2977
danjoy25's Avatar
Trader Rating: 38 (100%+)
I know where it should go? Anyway try to sort it out as I will be running there shortly
danjoy25 is offline
Old 05-16-2006, 11:34 PM
  #2978
Mad Mackem's Avatar
Sounds interesting Brad. Do they have them at Castle Hill Hobbies?
Thought you were a little young to take on the old guys yet Dan. Perhaps you are just aging well.
Old 05-16-2006, 11:48 PM
  #2979
Professor's Avatar
Default tamiya stock motors
jeff/brad
are these tamiya stock motors the rz/tz as used at tcs? & where do they fit in with speed comparison to 540,stock 27 turn or 19 turn motors?
gda
Professor is offline
  #2980
cannon's Avatar
Trader Rating: 35 (100%+)
Jeff,
I think Brad is referring toi the TZ and RZ 23 turn motors they use in the TCS racing. It does sound like a good option
The Super Stock Motor RZ is the second release in the 23T stock motors. Perfect for sprint racing and high-speed tracks, the RZ features higher revolutions than the Type RR Stock Motor. Features lay-down brushes, red anodized end bell with brush dampers, terminal heat sink, detachable chip capacitor and can be disassembled for easy maintenance.
•A high performance motor for electric radio control car use.
•A high revolution motor designed for sprint race or high speed track.
•Can be disassembled for maintenance. Features lay-down brushes
•Red anodized end bell with brush dampers.
•Features terminal heat sink and detachable chip capacitor.
?3 turn motor
•Usable voltage: 7.2V
•R.P.M. at best efficiency: 27,500rpm (7.2V)
•Torque at best efficiency: 500g-cm (7.2V)
•JRM certified motor.
With the popularity of touring car racing, there has been a growing demand for high performance 23T stock motors. To meet these demands Tamiya introduces the Super Stock Motor TZ. Perfect for endurance racing and low speed tracks, the TZ features more torque and higher revolutions than the Type S Stock Motor. Features standard brushes, blue anodized end bell with brush dampers, terminal heat sink, detachable chip capacitor and can be disassembled for easy maintenance.
•A high torque motor designed for endurance race or low speed track.
•Blue anodized end bell with brush dampers.
?3 turn motor
•R.P.M. at best efficiency: 26,500rpm (7.2V)
Or for that matter, any of the Jap Spec 23 turn motors... Yokomo, Eagle etc
cannon is offline
Old 05-16-2006, 11:52 PM
  #2981
Professor's Avatar
Default tamiya
cannon
posted at the same time,what sort of maintainance is reqd on the tz/rz are they like a 27 turn with brushesspring combos & com cutting?
gda
Old 05-17-2006, 12:00 AM
  #2982
cannon's Avatar
Same maintenance as 27 turn stock motors.
I am sure that I could get a very good price on these motors. As they are JRM spec, there are plenty of varieties available.
cannon is offline
Old 05-17-2006, 12:31 AM
  #2983
If you are going to run with the 23t motors, i would suggest keeping it restricted to the TZ/RZ Tamiya series. They are one of the cheapest, readily available, are reliable, easy to tech, and do not change series as often as some of the other brands, who literally release a new motor a month.
I think Jake Zarb used one of my TCS motors at the last MECA, and Rod used an RZ to finish second.
The only differences between them is one uses stand up brushes the other normal stock laydowns.
Jeff- I would be very surprised if Castle hill hobbies do not have them. Most shops, and even Dick Smith powerhouses will have stock of them.
Besercoe is offline
Old 05-17-2006, 01:43 AM
  #2984
Mad Mackem's Avatar
Well I guess it is all food for discussion on Friday. Any other suggestions or thoughts from other Senior drivers?
Old 05-17-2006, 03:54 AM
  #2985
vr01's Avatar
Jeff,
I think ultimately 19T would probably be the best option, however to keep the jump small, why not make it 27T Stock? I would hazard a guess that most of the Senior's already have one and are familiar with their characteristics. Save's having to buy a motor (23T) that isn't really useful anywhere else.
vr01 is offline
