Castle Hill RC Onroad
#2206
ill stick with the one-way, since i was going to get a ball diff, i havent got alot of money . But like everybody said, its the driver. Ill get a new 540 motor and put it in, run it in, gear it right, and try to focus on my consistantcy. Because in the secound rould of the challenge cup, thats why i lost, and a little to the dud grey johnston motor.; i shouldn't have a problem on friday. Ill try to do some consistant clean driving.
Thanks for the advise Marc
#2207
Originally Posted by theorbb
am i allowed to run a team associated RC10L3 at castlehill?
Coxy.
#2208
Set your car up right AND you will have some brakes WITH your oneway. I used brakes with a oneway and won mod last friday. It was nessasary to get the turn in at speed with the rubber (or lack of) that I had on.
Does your car come out off power or only when you brake?
#2209
It is most likely my tires, they are more than a year old and i can see the insert in them. What would be a good tire and insert for 540??? But with the oneway, ill leave it in cause it teaches me how to drive good. 2nd is not bad since i got knocked to the back of the pack when i started off. It like in the secounf heat when i could of won the heat but Ray Wallace lead me straight up a dome.
It sucks buy thats racing
#2212
Just a point about Ray. He did win the week before so he can't be that bad. We all have dificulty in passing in 540 as the top end speed just isn't there but it is part of the skill in doing well in the class, to position your car so that any contact will cause the least damage.
If you are down the inside of someone and they don't want to give way, then they will probably suffer the consequences.
#2213
#2214
Does anyone know how much Sorex 24R are from the shop???
#2217
Could you use Sorex 20's with soft type B Sorex inserts at castle hill.
