How to get traction
#16
Traction.
Originally Posted by soc123_au
Traction is all about weight transfer. Try & get the weight as close to equal on all 4 corners & the car should be fairly neutral. If you need rear traction add weight to the rear, more steering add weight to the front. I dont neccecerly mean put physical heavy things on your car. Use your droop screws & shock collars to adjust. Also changing the spring rates will affect this. I used to run the softest tyres I could get away with to help with traction. Now I make sure all of the above is right & I can run harder tyres with better results.
