HOBBYWING TECH SUPPORT INFO
#541
xr8 plus S
Salve, mi scusi per l'introduzione a questa discussione.
Sono un nuovo felice proprietario dell'esc. Guido con 2400kv in xray gtx 22. sperone 19/45, temperatura ambiente 25 gradi. L'esc è sempre superiore a 100/110. °
forza frenante 80% - br rate ctl 10 - br frequ 2k *-boost timing 0-turbo timing 35- delay 0.1-turbo incr.rate 12°/0,1s- trottle
rate contr 6-pwm 4k -soften value 0- gamma morbida 0 -
l'Esc è nuovo, primo allenamento ieri, cosa posso fare?
ho messo la ventola di alimentazione da 40 mm a lato di esc e le temperature scendono di 8° centigradi
anybody can help me ?? thanks a lot !!!
#542
what about italian linguage reference ? thanks a lot
#543
Hobbywing Xerun v3.1 1s
Hallo,
I have a Xerun V3.1 1S installed in my 1/12 car. I changed to the modified class and installed a Xerun V10 3.5 motor.
In practice everything worked fine. During qualification runs i experienced sudden loss of steering from the servo. Steering seems to come back after a few seconds. But it happened more often. While not having steering i had throttle and brake from the ESC.
Could there be an issue with the BEC voltage supplied to the receiver? The ESC was running quite hot.
Could i have fried something?
Thanks in advance
Thanks in advance
