-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Servos (https://www.rctech.net/forum/australian-racing/36713-servos.html)
Dan the Man 03-27-2004 03:04 PM
Servos
Ok, this is probably a newbie question.....:nod:
I run a JR radio/reciever combo, but I want to try using a different companies servo with them.
I have to re-wire the plugs, but I was just curious about whether servos take a standard voltage, or do they differ from brand to brand?
If the voltages do differ, where can I find that sort of info to compare them??
Timmy_G 03-27-2004 03:09 PM
what kind of servo do you plan on using with you're JR receiver. I might have some info as to which wires go where in the shed I could dig up for you if it helps.
I think the voltage is standard, though running a fet wire from the speedy may make a mild difference on some servos.
Tim
Dan the Man 03-27-2004 03:18 PM
Hey Tim,
Thanks for the offer, but I'm ok on the wiring harness.
Just curious about the voltages involved, not FET servos, just standard. I actually don't know what brand they are, as I found them in a box of miscellaneous bits and pieces, and of course, they haven't got the manufacturers label on them anymore...:lol:
Dragonfire 03-27-2004 05:09 PM
If its not a 7.2v fet servo, then it should be 6.0v (you can get fet servos in a 6.0v version that dosen't require a extra wire)
