V1RR and JR XS3 reciever
Hi,
I was trying to fit an RS300 reciever into the V1RR reciever box, however the reciever is too big. Does anyone know what will work to make the reciever be in the best spot on the car (less prone to damage)?
thanks,
Jason..
thanks,
Jason..
Re: V1RR and JR XS3 reciever
Originally posted by ieie
Hi,
thanks,
Jason..
Hi,
thanks,
Jason..
I run the same combo on one of my cars, what you will have to do is to cut one of the plastic sides of the holder off, preferably on the side where it is closer to the car not the out side. Then if you face it up to protect it you will need to drill 2 large holes together so you can adjust the the frequency. It works quite well once you make the mods and it keeps the receiver quite clean. Also you will need to cable tie it to the holder. If you get stuck PM me and i will try and explain it a bit better or I may be able to take a couple of pics and email them for you.
The Rock,
I was thinking of cutting the sides of the case. I've got a spare box so I can hack the sides of the one on there now...
If you can send a couple of pics to me of your job then I can see how low the reciever sits and how it looks.
Thanks for the info...
email is [email protected]
The Rock,
The Rock,
