mission v's MI2
#17
DZ, I made mine the same way the Mi2 manual recommends...
that is, to remove the main carbide diff balls (not thrust)..
clean the lubricant from the diff faces, and diff rings and reassemble...
tighten diff bolt until it locks...dont overtighten!...
I also did this to prevent damage to diff pulley from being clamped..
I used 2 peices of cardboard (cut from schumacher spares header card, into a circle...slightly larger diameter than diff rings, and a hole in centre... place against pulley between diff rings before reassembly...
Mine has operated faultlessly for 4 days now...hasnt slipped at all.
#19
Hey Gav. will schumacher be releasing the cardboard as a hot up option?
#20
lol...i'll look into that,,
but for the meantime, use cardboard from a spare parts header card..
at leasst it has schumacher written on it...
#21
racing lines
Hi King-G great artical in racing lines well done.
#22
which one??..Mission article or Japan worlds?..
cheers..
must catch up soon trev!.
cheers..
#23
tcs worlds
#25
I agree about the mission article was quite informative!
Well done.
When i read that, i went straight to the car and checked everything that you said hehe
Well done.
#26
Heavy : Is the mission article on the latest racing lines ? Do you still have a copy ?
King G : Thanks for the info .. i am ging to rebuilt my diff this week, so will be ready by next meet. Might try the spool diff. Hope it work for me since the track i am racing is consider thight and lot's of corners.
Ben
Ben
#28
hi, does the mission S1 include carbon fibre parts? or is it just a sport type version? would you guys reccomend it for racing?
#30
so whats the top deck made out of etc? coz i noticed the s1 is pretty cheap at frontline hobbies
