Meca Challange 2004 Motors for Stock??
Hi all, Meca is not too far away, What motors would you all be running in stock, Walter From Walter Hobbies came around Eastern Creek During Summernats, He said that there are some new 23T JRM Stock motors ie Force Pink and Force Purple. Does anyone know:
1. Which one is the Torque motor and which is the Rev motor?
2. Where to find stats on the motors, tried miwahobby.co.jp already and it had old motors only??
thanks
Nielonsx
thanks
Nielonsx
Stock motors for Meca
Don't bother running those motors, I would probably run a Binary motor if allowed.
there are some 23T motors which are supposed to rev beyond 33k, and still have to torgue to spin wheels im sure at EC they are better then the quad mag binary
Trader Rating: 22 (100%+)
i have the torque version of the Zenon 23turn, it has less revs than a monster stock, but the torque is insane. with a 41mm rollout, my motor came off cold after the first time running it with this rollout, but the brushes lasted about one run and then they died.
get a 23turn, they are cheap and FAST, you should nearly be able to do 19turn laptimes.
When is Mecca? Whats is Mecca? What classes are run? Is it nitro or electric?
meca is at the end of feb. not sure of exact date.
there is both electric and nitro(nitro-sat electric-sun)
all you monster fans should be quite at home with the atlas toyamitta 23t.
for those who like a p2k2 clone go for the atlas splash 23t.
I don't know anything about the new "force" series but usually motors get better so they should at least be ok.
these motors can be bought from walters for less than $70 last time i looked.
