replacement receiver wire
Hi Guys,
My reciever antenna has been accidently cut short in a smash and it still works @ the hill but I doubt it will work @ the creek or northside. Surely this is replaceable?!?!?!?! are these things sold seperatly or can I pick up the wire @ dick smith or something? It's for a 27mhz AM Futaba |
easy, open the receiver box, weld another wire . close it.
only cost u under 5 bucks. do not use other cables. only antenna wire. do u have soldering tools? i am in melb, I am happy to help u to fix this problem. FOC. i have a spare wire too. bring to my workshop, i fix for u. |
Originally posted by Franky easy, open the receiver box, weld another wire . close it. only cost u under 5 bucks. do not use other cables. only antenna wire. do u have soldering tools? i am in melb, I am happy to help u to fix this problem. FOC. i have a spare wire too. bring to my workshop, i fix for u. |
as i can remember, i read an article on the length of the antenna,
have to find it and get backto u. it talks about the 27mhz, and 29, or 40. they all have different .. if u r running 1:10 scale. the max length will no be longer than your car. if u get one from your local hobby shop. u may need to cut it ... normally they r too long.... |
in that article,
said... 300,000 KM / 27,000,000 = 11.11111 metre the best length of antenna is 1/2 of the wave length. 5.56 m but that is too long for rc cars. so take 1/32 for 1:10 that is 34cm for mini Z 1/64 will be 17cm for best reception... however i have no idea where the 300,000 km comes from.... |
for FM40. best length for 1:10 will be 23.4 cm.
Originally posted by Franky in that article, said... 300,000 KM / 27,000,000 = 11.11111 metre the best length of antenna is 1/2 of the wave length. 5.56 m but that is too long for rc cars. so take 1/32 for 1:10 that is 34cm for mini Z 1/64 will be 17cm for best reception... however i have no idea where the 300,000 km comes from.... |
just ask one of your mates to measure theres with a ruler.. :P
however i have no idea where the 300,000 km comes from.... lambda = wavelength (m) v = speed of signal (m/s) f = frequency (Hz) In this case, radio waves travel at the speed of light, 3x10^8 metres per second or 300,000 km/s. That's where 300,000 comes from. |
Me bad then, I just strip multicore communication cables and use the wire out of them and works fine. Cost me $0.00 since it was scrap anyway and I have heaps of colours to pick from :D
Originally posted by Franky do not use other cables. only antenna wire. |
Originally posted by au_Nightmare Me bad then, I just strip multicore communication cables and use the wire out of them and works fine. Cost me $0.00 since it was scrap anyway and I have heaps of colours to pick from :D |
Yes, its copper.. (well sure looks like it anyway) and so is the old original receiver wire.. unless something else looks like copper :)
Originally posted by Kennedy is that copper wire? |
Any copper wire will work.
Just go to Dick Smith's. Go to their self-service wire section and look for their skinniest thinnest wire, its only about 20c/metre & comes in 6-8 colours. I'd usually colour code it too.. eg black for 27Mhz purple or grey for 29Mhz white for 40Mhz If you haven't lost the broken part of your old wire, just measure the whole lot and put on a new wire of the same total length. If you can't find the broken bit, just find someone with the same RX on the same band whose wire is *known* unbroken and measure that length it is. Next time you're out with your car, best to do a Range Check. |
ill fix it on friday before racing if you want.
ill brings some wire with me that i have used before. ive done 2 AM29mhz and 1 FM27mhz and never had a problem with interference. takes 2secs to do. |
Originally posted by dontfeelcold ill fix it on friday before racing if you want. ill brings some wire with me that i have used before. ive done 2 AM29mhz and 1 FM27mhz and never had a problem with interference. takes 2secs to do. |
| All times are GMT -7. It is currently 08:29 PM. |
