-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   sensor,sensorless questions (https://www.rctech.net/forum/australian-racing/282254-sensor-sensorless-questions.html)
Peli 03-12-2009 06:52 AM
hi guys,just a quick question....i bought a lrp eraser stock spec 13.5 motor today,and on the package it says i can run it sensor or sensorless.....
i am going to hook it up to a mamba max speedy(sensorless)...is this going to cause any dramas or cook my speedy?
also,the mamba is wired in red/white/black on the motor wires
but the LRP motor is blue/yellow/orange...am i right in assuming that the polarity doesnt matter with brushless motors(i read in my mamba manual that u can swap the red and black wires to reverse the direction of the motor,but never swap the white wire)therefore my wiring from mamba to LRP should be
red/blue then white/yellow then black/orange?
sorry bout the simple questions,but i really dont want to let the magic smoke out of anything.....:cry::lol::lol:
cheers Justin
Bugle 03-12-2009 06:59 AM
Yeah I run sensored motors on my mamba max and it's fine.
Wires don't matter, just plug it up and if it spins backwards swap 2 wires around to get it to go forward.
Peli 03-12-2009 07:03 AM
thanks for the reply Bugle...what about the middle wires,the white on the mamba and the yellow on the Lrp...do they have to be aligned,then just swap the outers for correct motor rotation?
also,do you have to arm yor mamba every time u turn it on with full throttle,then full reverse then nuetral?
Bugle 03-12-2009 07:12 AM
It won't make a difference which way it's hooked up other than possibly having the motor spin the wrong way, you can just do it random, and then swap any wires to reverse the rotation.
I can't find in the mamba manual where they say not to swap the white wire? I'm looking at it and they say it doesn't matter which way it's done.
Mine seems to arm when it detects the neutral position, as soon as I turn the transmitter on. If i've got the wrong transmitter profile selected it won't arm until I select the right one then it arms instantly.
Peli 03-12-2009 07:21 AM
sorry,got confused about the white wire,it was in the brushed section,it says not to use it in brushed mode:confused:too many of the good beverages:lol::lol:
havent tryed the neutral position trick,i always turn the transmitter on first with the throttle on full,like it says in the setup manual...by the sounds of it,once its set,its set.....
do u have any issues with cogging,and what motor do u use?
thanks for all yor help Bugle,much appreciated.....by the way,the new track at st.ives looks killer,good work
Bugle 03-12-2009 07:30 AM
Yeah that's just for initial calibration. After that it just waits for neutral then plays the music and away you go!
I've only been running low turn motors like 5.5 turns and it doesn't cog, people say that higher turn motors will cog but haven't tried it yet. I'm going to get a 13.5 so i'll see how that goes.
Lets hope the weather stays nice so we can finish it hey!
Peli 03-12-2009 07:43 AM
just hooked it up and tested it,it works fine,but revs a little slower in reverse,but i think the reverse power was set lower on my castle link software:cool::cool:
i am running a LRP Eraser 13.5 on it at the moment to see how it goes in a slash,noticed a little cogging just holding it off idle,but nothing up top
i also tryed yor trick off letting it just register at neutral,it worked:cool:armed itself,and i had throttle:cool:...maybe i should have read my manual a bit better,just got to excited about unleashing the mamba power(5700kv motor)
its my first brushless setup,and the LRP is my first normal speed brushless,so im just checking to make sure its all going to run correctly.....
again,thanks for ya help Bugle,much appreciated:nod::):):)it all works fine....thankyou......
and hopeful the weather holds out for u guys,i'm running a crawler comp this weekend,so heres hoping for the both of us.....:lol::lol:
might have to come turn some laps on your track with the slash at some stage....
X5 Addict 03-12-2009 10:52 AM
Forget about using the colours as a reference, they are all labelled A B C. You just need to marry these up and all will be fine.
RacerEd 03-12-2009 08:45 PM
Yeah basically the higher turn motor you have the more chance of cogging as the rotor produces less back emf from the initial pulses that assess rotor position. Once your moving though there won't be a problem, its just from stationary.
I would have thought that 13.5 would have been borderline as my castle won't run 17.5 without cogging for a good 2sec before it takes off :flaming:
Runs fine with a 6.5 though :nod:
Peli 03-12-2009 11:26 PM
i only tested it in my rig with it sitting on the bech...it cogged at real light throttle...at slow speed...should be ok on the track,will test it fully tomorow arvo at ryde ......hopefully it doesnt rain:)
Bugle 03-13-2009 01:31 AM
Strange it cogs that bad on 17.5. I've got a hobbywing sensorless speedo + 17.5 motor in another car and if you hit full throttle from a standstill it cogs for a split second then goes would've thought the Mamba would do better than Hobbywing. Have to try it with the Mamba.
Tom they don't mark ABC on the Mamba it's just marked red white black, so you've just gotta take a guess when hooking the motor up
X5 Addict 03-13-2009 02:18 AM
You will use Mamba then....:lol:
If you have another motor you could reference where A B C should be?
