Go Back  R/C Tech Forums > International Forums > Australian Racing
Ryde it like you stole it: the Ryde Drivers thread. >
Like Tree54Likes
Old 04-24-2012, 08:10 AM
  #16006
nckmat's Avatar
Trader Rating: 24 (100%+)
Sunday is looking good, possible late shower, but we can live with that.
We are mainly rolling and laying ag pipe, but the more people we get the more we can do.
nckmat is offline
Old 04-25-2012, 03:00 AM
  #16007
Syndicate's Avatar
Hey stock 4wd'ers , im dropping my b44 back into stock, whats a good gear ratio to start at? 33/75 ?
Syndicate is offline
Old 04-25-2012, 03:11 AM
  #16008
jordy-15's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Syndicate
Hey stock 4wd'ers , im droppinf my b44 back into stock, whats a good gear ratio to start at? 33/75 ?
you should aim for a final drive between 5.5 - 6.0 its a suck it and see kind a thing the motor/speedy will be the main factor. try it and check you temps
cheers
chris
jordy-15 is offline
Old 04-25-2012, 06:05 AM
  #16009
daverobbo5's Avatar
Trader Rating: 45 (100%+)
Hi Reedy, Just my advice only. start a bit lower in the pinion department. maybe a 28 or 29 and work up from there with the 75 spur.
daverobbo5 is offline
Old 04-25-2012, 06:08 AM
  #16010
Radio Active's Avatar
cheers
chris
I've run my overall drive ratio as low as 4.9 at Maitland (higher elsewhere), but so far everyone else who has tried that after I've told them has smoked a motor, so maybe start at 5.5 to 6.0 like jordy says.
Radio Active is offline
Old 04-25-2012, 07:40 AM
  #16011
nckmat's Avatar
Ahh Daniel just the man to answer my question. My son asked me tonight why when you take a phot of the night sky with the exposure open for a whole night do the stars appear as circles instead of straight lines? I know I once knew this but I am starting to off load unimportant information to make new space on my chemical hard drive.
nckmat is offline
Old 04-25-2012, 12:47 PM
  #16012
Syndicate's Avatar
Yeah i had it at 72/34, thinking it would be similar to 2wd, but the motor was too hot in like 8 laps, (5.29)
might try 33/75, that gives me 5.68, might run that for a while and temp check it, i think that's the lowest pinion i own, after that its like <24
trip to the LHS might be on the cards...:|
Old 04-25-2012, 02:32 PM
  #16013
cghomann's Avatar
reedy you have to find the sweet spot for your motor, all motors are different some will need to be geared as high as 6 and others can go as low as 5. in my B44 fdr is 5.12 and the durango fdr is 5.36,same motor and esc.
cghomann is offline
Old 04-25-2012, 05:45 PM
  #16014
eddomak's Avatar
Old medieval answer: It's because the universe (sun, moon, stars) rotate around the earth...
Newer answer: The earth rotates on its axis (around its poles), and so things that are relatively stationary in the sky will look as though they are moving. You can achieve the same effect by standing up, looking up at the sky, then doing a 360 - things in your "sky" will seem to rotate around your axis.
There are ways of finding the point around which they all rotate (and hence where to position and aim your camera for maximum effect). A famous photo is at:
eddomak is offline
Old 04-25-2012, 06:14 PM
  #16015
nckmat's Avatar
That much I get, but if you are looking at it on the opposite axis of the Earth's axis why do you still see it as circles instead of East-West stripes? Ahh, does it only work if you point your camera true North? I have been watching a satellite lately looking South East and it seems to travel in a straight line.
nckmat is offline
Old 04-26-2012, 02:36 AM
  #16016
jordy-15's Avatar
Nick you have PM
jordy-15 is offline
Old 04-26-2012, 11:32 AM
  #16017
Syndicate's Avatar
Default results
I see the results have been updated, massive field in 2wd stock
I couldnt quite hear at the AGM, but we are racing for the whole year then dropping rounds correct?
Old 04-26-2012, 03:39 PM
  #16018
The Earth is spinning on its axis. The stars stay fixed (relatively). The diameter of the circle the stars trace out will be smaller the closer they are looking to the Earth's axis. In the South the Southern Cross is the constellation closest to the axis, so if you want to see the effect accentuated then try a long exposure (a few hours) of it.
To find the exact celestial pole take the intersection of the perpendicular bisector of the pointers (Alpha Centari and Beta Centauri) and the line drawn through the vertical (as seen on the flag) beam of the Cross.
Old 04-26-2012, 04:15 PM
  #16019
R/C Tech Elite Member
Roman's Avatar
Trader Rating: 28 (100%+)
Yes, there is one Sunday series and one Saturday series.
The number of rounds dropped depends on total rounds raced and according to the summary rules on page one of the point score results.
2wd stock is very popular this year, at club level and at major meetings.
Roman is offline
Old 04-26-2012, 05:12 PM
  #16020
HareTurtle's Avatar
Any word on working on the track Saturday (tomorrow) as well? Or are we consolidating the working bee to Sunday?
HareTurtle is offline
